fush mount fuel cap
  • jimmybon
  • jimmybon's Avatar Topic Author
fush mount fuel cap
07 May 2008 05:04
#211728
any one fitted a flush mounted fuel cap to an old kz tank, any tips?
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: fush mount fuel cap
07 May 2008 05:49
#211733
badkaw has a j-model he put one in.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
07 May 2008 07:28
#211753
KZR member 'kano' did one too' on an ELR tank...see the following:
kzrider.com/media/kunena/attachments/leg...no__s_kz1175r105.JPG
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jimmybon
07 May 2008 15:15
#211883
Thanks, looks like a kwaka brand cap as well
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Qdude
  • Qdude's Avatar
  • It is all good.
07 May 2008 16:15
#211898
There was someone else who cut in a new cap from a different Kawi's tank. He had a welder cut out the area 3-4 inches around the other/flat cap tanks cap and welded it to a hole he made in the existing tank. Then the whole refinish thing....
77 KZ 650 C1.
77 KZ 650 C1.
  • jimmybon
07 May 2008 16:39
#211910
OK, so I need to cut around the the filler cap on the doner tank and weld it into the same size hole made in the z tank. never thought of that, thanks heaps:cheer:
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • mcbartell
  • mcbartell's Avatar
07 May 2008 18:59
#211954
Just be sure to fill the tank partially with water, and don't heat it up too much because it WILL warp.
1976 KZ900
1981 KZ810 Four (sold)
1972 H1 Triple (sold)
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
1997 Tahoe (Toy Hauler) sold :(
2000 Bonneville SSEI
  • jimmybon
07 May 2008 20:38
#211973
good point, will do, cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • 531blackbanshee
  • Vendor
  • Vendor
08 May 2008 08:50
#212032
bad kaw's j-model flush mount cap.
  • jimmybon
08 May 2008 14:39
#212092
thanks 531, next thing is to find a suitable doner tank.
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
23 May 2008 12:26
#215354
Oy! Hey, sorry it took me a minute to get this thread...for some reason it was regitereing "read" on my computer...whatever.
Anyway: Yes, that's my tank; I've done it on at least three tanks, your welder needs to be the man as the metal is pretty darn thin. My machinist is a perfectionist and he told me that it's not a job for a shade-tree guy (like me). Make sure that you keep the drain tube so that you can have it welded in and routed on your new tank...if you don't keep it a tiny fuel spill over would turn into a messy clean up.
I have a friend with a salvage yard and I told him I wanted a bashed tank that had a good fuel cap with surrounding metal. He gets too much money for fuel caps, so what I ended up doing was watching eBay for cheap fuel tanks (remember they can be beat-up pretty bad as long as the material around the cap is still good) and I've purchased several and done the "J" tank you see above and a CB900F tank, and a GS1150ES tank and a GS1000E tank (that my friend had to have...so I sold it to him). But anyway, it's very do-able. My tank has black paint on it in that pic because I wanted to protect the bare metal during my 'mock up' of my project.
Good luck on your project and just drop me a line if you have any questions that I might be able to answer!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • jimmybon
25 May 2008 15:01
#215727
thanks badkaw, I'm looking at some tanks this week at a wrecker, he wants $50au for a complete tank smashed of cause. Said he sells the caps to builders of boats and speedway racers
did your machinist use a mill with a fly cutter? I was thinking just mark it out then use a dremel or 4" grinder to cut it out, the mill would definatly be more accurate
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
