Instrument Pannel Cover - neutral, oil pressure, brake, high beam
- KOOL RYDER
- KZ 650B2 / KZ 1000E
02 May 2008 14:27
Gents,
Two part question:Instrument Pannel Cover - neutral, oil pressure, brake, high beam
1) What is this part called? it is removed by unscrewing the plastic round nut around the key hole?
2) Can someone help me locate one, either new or in great shape?
Mine is a disaster and I have looked everywhere for it.
Thanks
Thanks
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- Bluemeanie
Re: Instrument Pannel Cover - neutral, oil pressure, brake, high beam
02 May 2008 20:33
Yes, the plastic nut holds it on. It's called many things but more commonly reffered to as a meter cover. They show up on ebay but mostly attached to spedo and tach. Still, buying a complete assembly would give you the cover and a spare set of gauges. If you come across some in ebay here are the ones that fit your bike..
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-G1 (Classic) (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ900-A4 (1976)
KZ900-A5 (1977)
- MadKaw500
03 May 2008 14:13
www.americanclassix.com
has them in stock. there may also be 2 screws in the back behind the headlight.
- Bluemeanie
03 May 2008 15:46
Your correct MadKaw500, but the two screws on the back only hold on the "back" cover. The "front" or "top" cover is held on only by the plastic nut around the ignition switch.
- MadKaw500
03 May 2008 19:58
oh, ok...I was replacing the ignition switch when I did this. guess it was all one mission.
- MadKaw500
03 May 2008 21:34Please Log in or Create an account to join the conversation.
- Bluemeanie
04 May 2008 07:30 - 04 May 2008 07:31
Last edit: 04 May 2008 07:31 by Bluemeanie.
