Rattle can gas tank paint job, meets liquid gas!!
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
28 Apr 2008 15:43
#209857
Ok. I knew that it would attack the paint.
How do I amend it. Do I strip the wax and get it with the 2000 grit wet/dry, rubbing compound, swirl remover and wax again?
Any suggestions as to how to fuel proof it better?
77 KZ 650 C1.
77 KZ 650 C1.
  • HerrDeacon
  • HerrDeacon's Avatar
Re: Rattle can gas tank paint job, meets liquid gas!!
28 Apr 2008 17:44
#209889
Do you have any pics of the damage? I just rattle canned mine and I'm afraid of the same thing.
  • ronjones
  • ronjones's Avatar
28 Apr 2008 18:51
#209895
same thing recently happened to mine. I tried compound and it helped some. It doesn't look as if it got to the paint, so I've rewaxed. Maybe I'll hit it w/the compound a couple of more times. I'll probably wait until winter and go at it w/1500 and reclearcoat...if I don't just strip and redo in another color.
  • Qdude
  • It is all good.
28 Apr 2008 21:33
#209948
Yes Deacon, I will get some better pics of it tomorrow. It was hard to get a good angle on the slight, slight damage to the finish.
Mr. Jones, I wonder if it would be a good idea to strip the wax or not. Otherwise I will do some wet sanding to the affected parts, and buff, swirl and wax again.
Any input as to how to better fuelproof the finish?
77 KZ 650 C1.
77 KZ 650 C1.
  • JohNLA
  • JohNLA's Avatar
28 Apr 2008 21:56
#209955
I have seen threads where the guys have talked about expensive clears in a can. Some with hardeners and such.
A search should locate them.
I am going to pay to have my clear done. Hopefully, by Mark Wing.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
  • Beatpoet
  • Beatpoet's Avatar
29 Apr 2008 00:58
#209967
I've talked to my local auto parts store... They have gas-resistant clear in a can.
  • snorules
  • snorules's Avatar
29 Apr 2008 09:21 - 29 Apr 2008 09:22
#210028
I used PJ1 epoxy clear in a can, very gas proof, and only about $7 at my local shop. The most current paint job on my bike is gloss black rustoleum appliance epoxy. Looks better than some factory paint jobs I've seen, gas proof, and takes wax very well. Just pay close attention to the re-coat window on whatever paint you use, I had to redo my side panels because I waited longer the 1/2 hour, but less than 1 week....to paint alligated terribly.
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Last edit: 29 Apr 2008 09:22 by snorules. Reason: spelling
  • Qdude
  • It is all good.
29 Apr 2008 09:36
#210032
This is ok, I can do my gas tank a fourth time!!
I need to look into stripping the wax, and painting an "epoxy clear" or "gas resistant clear" over the existing enamel clear....
If I remember correctly, enamel over laquer is good, laquer over enamel is bad.
I imagine that the fuel proof clear will also be more resistant to the inner thigh scuffing that has dulled the finish on the sides of my tank.
77 KZ 650 C1.
77 KZ 650 C1.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
29 Apr 2008 10:01 - 04 Dec 2008 06:04
#210035
del
Last edit: 04 Dec 2008 06:04 by JMKZHI.
  • snorules
  • snorules's Avatar
29 Apr 2008 17:53
#210142
Sorry....gas proof...as in, I spilled enough gas thanks to a nozzle "cough" to cover the tank. not a a single soft spot or smudge.
  • Qdude
  • It is all good.
29 Apr 2008 19:47
#210176
I want to re-clear coat. I will do this over the existing enamel clear coat.
I need to remove all the wax that I applied.
So any recommendations as to which chemicals to use to best strip the wax prior to re-clear coating?
How do I be sure to remove all wax?
77 KZ 650 C1.
77 KZ 650 C1.
  • snorules
  • snorules's Avatar
30 Apr 2008 06:57
#210269
Call your local auto paint store. I think they have stuff that will strip the wax, but not harm the paint.
