Bare Metal Tank
- mcbartell
Bare Metal Tank
07 Apr 2008 07:36
I recently started work on my KZ750 project bike. The first thing I wanted to do is re-finish my tank. After sanding all the paint off, I realized that i really liked how it looked. My friend has done the same thing with his sportster and he finished it off with just a clear coat. Should this be enough to keep it from rusting/being damaged?
1976 KZ900
1981 KZ810 Four (sold)
1972 H1 Triple (sold)
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
1997 Tahoe (Toy Hauler) sold
2000 Bonneville SSEI
- jrjstuff
Re: Bare Metal Tank
07 Apr 2008 08:46
You know I liked that look on mine when I did the same thing but decided against it when I realized I wouldnt be able to have a flowing scheme due to the plastic side covers. As for your question, I am sure that so long as you have the metal clean a clear would protect it and if not at least you will be able to see the rust, shoule it happen.
Jeff
83 KZ750 ltd
83 KZ750 ltd
- PLUMMEN
Re: Bare Metal Tank
07 Apr 2008 09:46
years ago there was a 78 1000 running around omaha that had a chrome plated gas tank,i thought it was a little weird but it seemed to hold up.my hodaka dirtbikes when i was a kid had chrome gas tanks from the factory;)
- bountyhunter
Re: Bare Metal Tank
07 Apr 2008 09:48
mcbartell wrote:
If the clearcoat can handle gasoline without getting dissolved. Most won't.I recently started work on my KZ750 project bike. The first thing I wanted to do is re-finish my tank. After sanding all the paint off, I realized that i really liked how it looked. My friend has done the same thing with his sportster and he finished it off with just a clear coat. Should this be enough to keep it from rusting/being damaged?
- mcbartell
Re: Bare Metal Tank
07 Apr 2008 20:51
My friend clear coated his about a year ago and it is still holding up pretty good, as of last fall. We haven't looked at it since it was put in storage.
1976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
- Qdude
- It is all good.
Re: Bare Metal Tank
07 Apr 2008 22:02
I would think the clear coat would do the trick. Question is, how to get the sides and tail to look bare-metal'ish.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: Bare Metal Tank
07 Apr 2008 23:54
Qdude wrote:
Simple. Just fab up replacements out of scrap metal.
:blink:
West Linn, OR
- mcbartell
Re: Bare Metal Tank
08 Apr 2008 12:03
I will probably grind down the front fender and leave the side covers the way they are. I don't have plans to put on a tail piece, if I do it will be the stock fender tucked under the frame. The section of frame sticking out will probably be cut off and braced up.
1976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
- mcbartell
Re: Bare Metal Tank
26 Apr 2008 15:53
Thanks for the imput everyone, now my tank is finally done. I did all the grinding, layout, and spraying myself. The stripes are just Dupli Color Black. I took it in to the local body shop and they put on the orange pinstripes and seven coats of clear. It really has a nice smooth finish and is REALLY glossy
. I am really happy with how it turned out.
1976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
- mcbartell
Re: Bare Metal Tank
26 Apr 2008 16:021976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
- mcbartell
Re: Bare Metal Tank
26 Apr 2008 16:02 - 26 Apr 2008 16:05
Glossy
1976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
Last edit: 26 Apr 2008 16:05 by mcbartell.
- mcbartell
Re: Bare Metal Tank
26 Apr 2008 16:151976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
