First "real" paint job questions
  • EasyRider1
  • EasyRider1's Avatar Topic Author
18 Feb 2008 12:20
#195366
Ok, so I'm planning on painting the tank, side covers and tail section on my kz650 when it warms up outside. I will be using Acrylic Lacquer. I will be using prevals to do the job. Here are some of my questions:
1. Can I just prep and paint over the factory paint job or will I need to strip or prime or anything?
2. What type of paint was used on a 78 model kz650?
3. Should I do anything different to prep the plastic pieces as opposed to the tank?
I'm sure I will think of more questions but that's enough for now. Thanks for your help.
Post edited by: EasyRider1, at: 2008/02/18 15:21
1978 KZ650C
  • baldtire
  • baldtire's Avatar
Re: First \"real\" paint job questions
18 Feb 2008 19:11
#195443
i'am in the same boat as you, and heres what i found out
the guy at the paint store steered me away from lacquer
actually i gave him the paint code from my ford truck and he gave me some choices, so it's ppg omni urethane
if the thinner/reducer for the new paint doesn't mess up the original paint all is well
i don;t know what's on it now
there is a flex additive for urethane but i don;t know about Lacquer
i'am sure someone knows more than me will help out
  • PLUMMEN
  • PLUMMEN's Avatar
18 Feb 2008 21:51
#195479
laquer is very hard/brittle stuff,id try some kind of enamel so you dont have to worry about paint lifting;)
  • 2M4Dale
  • 2M4Dale's Avatar
19 Feb 2008 03:54
#195495
ppg omni urethane = great stuff. My painter swears by this stuff ! It's whats on my bike !!!
Whatever paint you use the finish depends on the prep. The better you prep the nicer your paint job will come out !!!
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Feb 2008 07:50 - 03 Dec 2008 20:53
#195535
del
Last edit: 03 Dec 2008 20:53 by JMKZHI.
  • EasyRider1
Re: First
19 Feb 2008 08:40
#195546
Well, I've already spent the money and bought the lacquer so that's what I'll be using. I know that lacquer blends and is easier to make it look professional without pro tools. Is the original paint on these old kaws lacquer?
Also, enamel takes a LONG time to cure while lacquer is ready to go rather quickly.
Post edited by: EasyRider1, at: 2008/02/19 18:54
1978 KZ650C
  • baldtire
  • baldtire's Avatar
Re: First
19 Feb 2008 12:38
#195597
JMKZHI, heres something to consider
www.uschem.com/index.cfm?page=productDetail&id=141&pid=2
that looks real nice
  • EasyRider1
Re: First
20 Feb 2008 19:53
#195948
Somebody has to know what type of paint was originally used in the late 70's by kawasaki. Somebody help me out if you know. Thanks
1978 KZ650C
  • PLUMMEN
  • PLUMMEN's Avatar
Re: First
20 Feb 2008 22:54
#195975
cheap production enamel.you need to find out what kind of a sealer you can use over the enamel.laquer was popular back in the 50s-70s because you could just water down the driveway or local carwash bay:whistle: :P and just starting laying down 20-30 coats of paint over bugs and all and just wet sand the hell out of it till it was smooth;)
  • EasyRider1
Re: First
21 Feb 2008 19:03
#196168
Do you have any idea what to look for in a sealer/barrier coat? Or where to buy it? Should I just strip the factory paint to do this?
1978 KZ650C
  • PLUMMEN
  • PLUMMEN's Avatar
Re: First
21 Feb 2008 20:08
#196185
check your pm;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: First
22 Feb 2008 12:55
#196312
I like wax.
