First "real" paint job questions
  • EasyRider1
  • EasyRider1's Avatar Topic Author
Re: First
22 Feb 2008 16:30
#196343
Duck wrote:
I like wax.
Please explain
1978 KZ650C
  • EasyRider1
Re: First
24 Feb 2008 10:07
#196667
PLUMMEN wrote:
cheap production enamel
Are you 100% positive that it was emamel and not lacquer?
Post edited by: EasyRider1, at: 2008/02/24 13:07
1978 KZ650C
  • baldtire
  • baldtire's Avatar
Re: First
24 Feb 2008 19:56
#196840
get some stripper then it won't matter
  • PLUMMEN
  • PLUMMEN's Avatar
Re: First
24 Feb 2008 21:00
#196857
the ones ive had over the years were enamel,its been a few of them!:P
  • EasyRider1
Re: First
25 Feb 2008 05:49
#196897
Yeah, but what about the plastic parts?
Post edited by: EasyRider1, at: 2008/02/25 08:50
1978 KZ650C
  • Locozuna
  • Locozuna's Avatar
Re: First
25 Feb 2008 06:30
#196903
Aircraft stripper is good for the metal. There is a citris stripper that is not as aggressive for the plastic. Better on the plastic is just sand them smooth or rough the paint to increase tooth. But keep your eye on the plastic I did melt a 750 sidecover to uselessness. Couldn't tell until I went to clean off the stripper. If they are in any good shape at all I'd just sand smooth.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Re: First
25 Feb 2008 07:17
#196906
Am recalling an earlier thread with suggestion for using brake fluid to safely remove paint from the plastic parts (side covers and tail piece). Perhaps soaked for awhile inside a zip-lock baggie??
Have never tried this, so please await confirmation advice before attempting it. :)
  • PLUMMEN
  • PLUMMEN's Avatar
Re: First
25 Feb 2008 09:21
#196915
tried acetone one time,big mistake!:blink: :ohmy: :sick: :( :unsure: :S :dry: :huh: :blush: :whistle: it came in a plastic plastic bottle,just wast an abs plastic bottle!:P
  • BSKZ650
  • BSKZ650's Avatar
Re: First
25 Feb 2008 09:47
#196925
One thing to remember about Lacquer, if you spill gas on it while filling up its going to mess the paint up, I am not sure how you were able to buy lacquer since the EPA killed it for the most part in automotive paint, but if you did then get some clear to put on it also, it will help protect somewhat.
As far as strippers I am not a big fan of them, if the surface is in good shape then a through wet sanding and primer job will work, I like to use the epoxy sealer primers, they have worked the best for me
77 ltd1000, current rider
76 kz900, just waiting
  • EasyRider1
Re: First
25 Feb 2008 11:39
#196937
I will be putting clear on top but that will be lacquer too so I guess that it will still be a risk. Lacquer is not supposed to be affected when gas hits it but it is possible (depending on what additives are in the gas or due to lower quality paint I suppose). I bought the lacquer from tcpglobal
1978 KZ650C
  • JMKZHI
  • JMKZHI's Avatar
Re: .
25 Feb 2008 11:49 - 03 Dec 2008 20:51
#196938
del
Last edit: 03 Dec 2008 20:51 by JMKZHI.
  • BSKZ650
  • BSKZ650's Avatar
Re: First
25 Feb 2008 13:37
#196951
Years ago Lacquer was the stuff to use if you wanted a deep shine, I still like to looks better than the clear coats, but the paint is soft as compared to the new base coat clear coat systems, and gas will ruin the finish.
About 18 years ago I apinted a friends XS1100 with lacquer looked great until he spilled some fuel on a fill up, I was able to polish it out but we both knew where it was.
For my money I would purchase some new paint, why go to all the prep work on the parts only to have them messed up real easy by something like a gas spill or some scratches and chips, just me two cents worth
