Custom Sissy Bar Project
  • 2M4Dale
  • 2M4Dale's Avatar Topic Author
03 Nov 2007 18:56
#179488
My wife and one of my daughters refuse to ride with me because they feel they need some sort of backrest. Soooo ... I have started making myself up a bit of a custom sissybar.
I made a template out of cardboard sheet .... well several templates till I got it right ... then cut out the side plates from .125 sheet steel on the junky old plasma cutter at work.
This pic is of the two side plates welded (tacked) together in order to finish the edges and have the plates uniform.
I've only just started this project ... more pics as I come along with it !
Post edited by: 2M4Dale, at: 2007/11/03 21:57
Post edited by: KZCSI, at: 2008/01/05 13:03
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • The Milkman
  • The Milkman's Avatar
Re: Custom Sissy Bar Project
03 Nov 2007 19:20
#179492
Looks interesting keep the pics and descriptions,,
Ride safe
  • 2M4Dale
23 Dec 2007 05:47
#186122
I've made some more headway on this little side project ! The pics show the sissy bar I'm gonna use kindof just being held in place by my nephew so we could get a visual.
And another pic of the sissy bar and side plates.
This pic shows the perimeter of the side plates semi-finished / ground to shape and the mount holes drilled and test fit to parts bike.
Side plates have been flattened out pretty good and here they are on the surface grinder at work ready to start the finishing process.
I still have a bunch of work to do to the sissy bar. and side plates .... I'll keep this project thread updated as I move along.
Post edited by: 2M4Dale, at: 2008/01/05 13:48
Post edited by: KZCSI, at: 2008/01/05 19:29
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • 2M4Dale
23 Dec 2007 06:08
#186125
Anyone know of a good chromer I can send this stuff to once I'm done ???
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • 2M4Dale
23 Dec 2007 07:37
#186136
I'm also gonna modify the sissy bar to use this cool Ebay find !!!
Post edited by: KZCSI, at: 2008/01/05 13:05
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • rdgrnr
  • rdgrnr's Avatar
23 Dec 2007 07:48
#186138
2M4Dale,
This is your lucky day. I work at a very large plating shop here in Minnesota. We use the Show Chrome process, which is nickel strike, copper, semi-bright, bright, and chrome. If you want, send me pics of what you want done. I can work something out with the shop to make this economical for you. One question though, is that Kawi emblem cast, aluminum, or steel?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • 2M4Dale
23 Dec 2007 07:58
#186139
AWESOME .... I should be ready for chromeing in a couple of weeks ! I will definately let you quote the job for me. Let me get further along with the fabrication and then I'll get ahold of Ya and we'll go to the next step !!! I may want to get some other "stock" items done like my fenders, etc.
The Kawi Eagle seems to be made from bronze with a pewter finish ... it is quite heavy. It is a OE Kawasaki item. It has a Kawasaki part number ... K53033-003 . My Eagle is NOS and was shipped from the Ebay vendor complete in the factory packaging and even came with the OE mounting bolts.
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • rdgrnr
  • rdgrnr's Avatar
23 Dec 2007 08:10
#186140
Ok,
just let me know when you are ready. I will need pics of everything you want done when the time comes. Cool
find on that emblem B)
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • 2M4Dale
23 Dec 2007 18:31
#186229
Thanks and I will !!!
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • 2M4Dale
04 Jan 2008 03:36
#187602
rdgrnr, and anyone else who may be interested ... I've made a bunch of progress on this project this past week and may be ready to send this stuff off to the chromer by early next week ... I'll post up some fresh pics this evening.
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • rdgrnr
  • rdgrnr's Avatar
04 Jan 2008 04:17
#187603
ok,
I've got a hockey tournement most of the weekend, but I will check in periodically when I am home for updates and pics. If you can, would you be able to send those pics to my email?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • 2M4Dale
05 Jan 2008 09:40
#187761
rdgrnr, I still didn't get as far as I wanted to ... but progress is progress .... I have to wait for my finish welder to weld everything up so I can do the final metal work, fit and finish. Once I have everything ready for chroming I'll get you some pics via email ... Here are some pics of where I'm at right now.
Sissy bar mount pockets made >
Eagle mount made and mocked up for this pic ... still gotta cut out some of the original sissy bar >
Side plates being surface ground to finish >
1980 KZ750H1 LTD
1981 KZ750H2 LTD
