fenderless tail mod
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar Topic Author
fenderless tail mod
13 Sep 2007 09:31
#170352
Just thought I'd post a couple of pictures of the tail mod I did last weekend.
Used an earlier tail than the stock '76 because I prefer the rounder tail light rather than the squarer one that came on the 76.
Post edited by: BARNEYHYPHEN, at: 2007/09/13 12:33
  • BARNEYHYPHEN
Re: fenderless tail mod
13 Sep 2007 09:33
#170353
Sorry, here's the other side.
How do you post more than one picture in a single post?
  • andoman
  • andoman's Avatar
13 Sep 2007 10:19
#170360
Looks great! Can you give us a shot from underneath? And maybe some specific steps or even a sketch?
Thanks!
  • BARNEYHYPHEN
13 Sep 2007 13:02
#170375
Thanks. I'll try to get some better shots tonight.
Made the mod out of s/s (16ga?). bent it all up at a friend's sheetmetal shop and welded the corners (overkill). End result was a kind of 5 sided cube (open at the bottom), with a very slight angle to the face that the light attaches to. Then a second plate of s/s with a bend across the middle (horizontal) which is sandwiched in place between the first "box" and the light, when the light is attached. Kinda winged it as I went along.
Don't know how to draw on the computer so I'll sketch it out and scan it.
  • cgray34
  • cgray34's Avatar
13 Sep 2007 14:57
#170393
Nice Job!
I do not have access to a sheet metal shop so I went to lowes and bought a strip of aluminum that was about 3/8" thick. I bent it in my garage with vice accordingly and was able to easily fabricate my own bracket. Not as sturdy as welded steel, but I think it will get the job done.
  • BARNEYHYPHEN
14 Sep 2007 07:07
#170515
CGray34, nice job, very clean look. Which light did you use?
The next 6 posts will be additional photos...
  • BARNEYHYPHEN
14 Sep 2007 07:08
#170517
2 of 6
  • BARNEYHYPHEN
14 Sep 2007 07:09
#170518
3 of 6
  • BARNEYHYPHEN
14 Sep 2007 07:09
#170519
4 of 6
  • BARNEYHYPHEN
14 Sep 2007 07:10
#170520
5 of 6
  • BARNEYHYPHEN
14 Sep 2007 07:12
#170522
6 of 6
You might note I did som fairly heavy grinding on the edges to smooth and to lessen the heavy profile of the sides of the "box" so it would be hidden under the tail.
  • BARNEYHYPHEN
14 Sep 2007 07:13
#170525
7 of 6....just checking you're still awake out there. There is no # 7.
