Seeking bearings for wheel swap. Custom GSXR front end....
- caffcruiser
Re: Seeking bearings for wheel swap. Custom GSXR front end....
05 Dec 2006 18:40
Sandy wrote:
Cool beans. Thanks a bunch.
Caff...I've got My feelers out,and I have 2 more places to check tomorrow,Bud...I'll let You know tomorrow(Wednesday)if I can match anything for You,so just hold on...
- wireman
05 Dec 2006 20:25
ive been looking on buchanons with my tongue hanging out of my mouth but i havent been able to find 17 x 5.5" rim ,where did you find yours at?
- caffcruiser
05 Dec 2006 21:37
wireman wrote:
At Buchanan.
Excel Takasagos, undrilled (must have them drilled for your hub).
www.buchananspokes.com/Excel_undimp.htm
The 5.5x17 is on there.
The 3.5x17 is a pre drilled unit:
www.buchananspokes.com/Excel_dimp.htm
REAR PART # REWM1417
FRONT PART # REWM61740
Also, they don't have a spoke kit for our bikes for 17's, so you'll need custom spokes and nipples to mate them up.
I went with the heaviest gauge of spokes they had, and some nicer high quality nipples.
All said and done retail on my purchase should have been close to $850.00/$900.00.
Having a huge discount at a motorcycle shop you work at that sells for Buchanan helps though.
They are a great company to deal with.
As for tires, I'm gonna be running Pilot Sports.
These rims obviously need to be run tubed, and the pattern on the inside of Pilot Sports is really friendly to a tube. A few of the guys at work who run motard bikes use them.
Good performance, good price through the shop, and good compatibility.
****EDIT: Added pic of tires.
Post edited by: caffcruiser, at: 2006/12/06 00:40
At Buchanan.
- Sandy
- Fly High,Tony
06 Dec 2006 16:55
Well,the closest I could find is 25x47x12.
1977 KZ1000 A-1
- wireman
06 Dec 2006 16:59
caffcruiser wrote:
thanks!
ah thats where i screwed up,didnt look in undrilled section!wireman wrote:ive been looking on buchanons with my tongue hanging out of my mouth but i havent been able to find 17 x 5.5" rim ,where did you find yours at?
At Buchanan.
****EDIT: Added pic of tires.<br><br>Post edited by: caffcruiser, at: 2006/12/06 00:40
- caffcruiser
07 Dec 2006 20:00
Sandy wrote:
It was worth a try.
Thanks anyhow though!
I ended up buying a 10 pack of those exact bearings on ebay for $10.00.
I'm just gonna bore out the stock hub to accept a 47mm front bearing. The only part that will be pretty thin is the seal retaining pocket... which is fine, cause the seal doesn't get a load on it, comparably.
I'm overboring the rear end to take a bearing too... the stock bearings from the R6 are 28mm ID by 62mm OD... which there is plenty of room for.
Like I said though, thanks anyhow!
It was worth a try.
- Sandy
- Fly High,Tony
07 Dec 2006 20:36
Any time,Bud.
Good luck with that eh,and let Us know how it worked out for Ya.
(pics of what You're doing too,don't forget :whistle: )
1977 KZ1000 A-1
