Seeking bearings for wheel swap. Custom GSXR front end....
- caffcruiser
04 Dec 2006 19:25
If anyone can find these (or give me a lead on a place that might have them) I would be greatly appreciative.
What I need is two wheel bearings. 40mm O.D. X 25mm I.D. (bore) X 12mm thickness.
I am building some custom 17" 40 spoke wheels for the bike. I'm running the KZ650 front hub, and the KZ1000 rear hub. GSXR forks (2002 750) on the front and a 2005 Yamaha R6 rear end.
The bearings are the right spec to run the KZ650 front hub (o.d.) and the GSXR front axle (i.d.).
I'm gonna need to find the same stuff for the rear end as soon as I get my rear axle and get the measurements.
***Any other ideas on how to go about this swap would be greatly appreciated too. I'm kinda considering using a custom made front/rear axle maybe. That way I can run stock bearings on the bike.
- Sandy
- Fly High,Tony
Re: Seeking bearings for wheel swap. Custom GSXR front end....
04 Dec 2006 19:39
I'll check My loacal Auto-Parts store in the a.m.,BudB)
1977 KZ1000 A-1
- wireman
04 Dec 2006 20:05
caffcruiser wrote:
im guessing the gsxr front axle is larger than the which would make it dificult to run stock kzbearings without making bushings for forks to make up the differance in smaller axle.is there enough material in the hub to bore it to the od of the stock suzuki bearing?If anyone can find these (or give me a lead on a place that might have them) I would be greatly appreciative.
- caffcruiser
04 Dec 2006 20:27
wireman wrote:
I'll look into the boring idea.
The part about running the stock bearings was if I had some custom axles turned.
Here's a diagram. The orange part of the axle is the part that would be built to KZ specs. The diameter would be made to go through the KZ wheel bearings. The red parts would be made to fit the GSXR axle retensions on the forks. These could also be made to be part of the spacer system that would hold the KZ hub centered.
caffcruiser wrote:im guessing the gsxr front axle is larger than the which would make it dificult to run stock kzbearings without making bushings for forks to make up the differance in smaller axle.is there enough material in the hub to bore it to the od of the stock suzuki bearing?If anyone can find these (or give me a lead on a place that might have them) I would be greatly appreciative.
- caffcruiser
04 Dec 2006 20:40
Ok, forget the bearings.
I had the wrong specs for the GSXR's.
The stock GSXR are 25x52x15. There'd be nothing left if you bored the hub, and there's a very slim chance of finding 25x40x12's anywhere.
Looks like the front and rear are gonna need custom axles turned.
- scumbag
- Lewd, Screwed, and Tattooed
04 Dec 2006 21:41
well that figured it self out real quick...kustom it is...haha..sweet!!!
sept.1976 kz650
1980 kz650
1980 kz650
- wireman
05 Dec 2006 08:31
caffcruiser wrote:
yeah that looks like the stock kawasaki design there,cool i like the looks of wire wheels myself over mags;)wireman wrote:caffcruiser wrote:im guessing the gsxr front axle is larger than the which would make it dificult to run stock kzbearings without making bushings for forks to make up the differance in smaller axle.is there enough material in the hub to bore it to the od of the stock suzuki bearing?If anyone can find these (or give me a lead on a place that might have them) I would be greatly appreciative.
- wiredgeorge
05 Dec 2006 10:45
Look in a phone book for a store that specializes in bearings. The bearings you need will be referred to as electric motor bearings. Give them the dimensions and see what turns up...
- caffcruiser
Agreed 100%. Especially when they are 40 spoke 17's with a 5.5" rear rim.
- caffcruiser
05 Dec 2006 12:13
wiredgeorge wrote:
Will definitely give that a shot.
I found 25mm ID by 47mm OD bearings. Lots of Ducatis and Aprilias use them, and we can get them in at the bike shop I work at since we deal Ducatis.
I'd have to have the hubs overbored to accept them, but I think it would be easier than getting custom axles turned.
- wireman
05 Dec 2006 16:19
caffcruiser wrote:
Agreed 100%. Especially when they are 40 spoke 17's with a 5.5" rear rim.![]()
- Sandy
- Fly High,Tony
05 Dec 2006 18:08
Caff...I've got My feelers out,and I have 2 more places to check tomorrow,Bud...I'll let You know tomorrow(Wednesday)if I can match anything for You,so just hold on...
1977 KZ1000 A-1
