Steering Stem Bearing Kit Install
- inline79
25 Nov 2006 00:13
Hi,
I've been replacing wheel bearings this week and thought I'd tackle the steering head while I had the front wheel off. I paid a bit more than I should have ($60CAD) for the AllBalls Kit, but it didn't come with any installation tips.
I had a heck of a time pounding the old races out. In the photo below I've matched everything up and I'm pretty sure I just have to hammer the new races in carefully and lube up the rollers, right?
The lower race of the lower bearing was really jammed on to the steering stem, does that need to be hammered into the stem or will it press itself onto the stem as that funny nut is hammbered tight? THe PO really wrecked that funny nut as well as breaking off the bolt on the front brake union mount. Gawddamn POs!!!
With the wheel bearings done, it's been a long week of pounding.. ahem, on bearings!
- KZQ
- Online
- Administrator
Re: Steering Stem Bearing Kit Install
26 Nov 2006 08:11
Hi Inline,
No the funny nut will not serve to seat the lower cup. I suggest that you look around for a good size match amongst your larger sockets. Find one that'll fit without damaging the actual race way and drive it home. The most important think is to keep it squared up and driving straight. To drive the cone over the steering stem I use a sixteen inch piece of 1 1/4" EMT conduit as the driver.
Good Luck
KZCSI
Good Luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- wireman
26 Nov 2006 09:58
piece of 3/4" allthread a couple 1-1/4 pvc fittings a couple 3/4" nuts and a couple really big fender washers,make yourself a press!
- xstreamcanadian
04 Jan 2007 22:00
hey there
did you get your kit installed? I am in chilliwack and have the same kit to chuck in, wondering how yours went.
xc
xc
- 76LTD
06 Jan 2007 17:58
I am installing an all balls kit on my 76 LTD. Haven't received the kit yet but it should be here soon. I have been wondering if one needs to reinstall the stock bottom steering stem seal and that flat washer below that. I guess the kit comes with a seal for the bottom bearing.
I saw the all-thread trick for installing the steering stem bearing parts in the frame head on American Chopper. It seemed to work great for them.
- Biquetoast
- King Jeremy The Wicked
06 Jan 2007 18:17
76LTD wrote:
I've done this replacement on the 400 and the 750. On the 400, I managed to reuse the washer at the bottom with the rubber seal somehow. On the 750, there was just no way to reinstall the seal. I tried it a couple ways and it just wouldn't work. so, no bottom seal for me. I just made sure the bearing was well-packed (make sure you learn how to properly "pack" a bearing), and I'll just check up on it later...
... I have been wondering if one needs to reinstall the stock bottom steering stem seal and that flat washer below that. I guess the kit comes with a seal for the bottom bearing....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- EsaPro
26 Jan 2007 17:47
OK, trying to revive this thread, since it is *exactly* what I am up to right now. Got the AllBalls kit today, since I noticed (once I got everything off the trees) it is a bit grindy, and has that "center dimple effect". OK, it came apart easy enough (39 balls hitting the floor - I will *never* find them all!), but now I need to bang out the races inside the stem, top and bottom.
I have beat the crap outta the lower one with a large flat screwdriver and a 1lb hammer (Figured it would be easier than going "up" on the top one) going around trying to keep it going out even. My hands are sore, my arms ache, and that sucker has moved ever so slightly (Think glacial movement).
What's the trick? PLEASE tell me there is a trick! :blush:
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
- Biquetoast
26 Jan 2007 18:05
EsaPro wrote:
Sorry dude, that *is* the trick.
Watch it though - you think you're even and not be. If you get just a teeeny bit off, you catch the side and start digging in to the metal.
If you absolutely are getting nowhere, as a last resort, you might want to tap it back and check to make sure you're not digging in...
....going around trying to keep it going out even. My hands are sore, my arms ache, and that sucker has moved ever so slightly (Think glacial movement).
kz750twins.com
kz750twins.com
- EsaPro
26 Jan 2007 18:09
Thanks, BT. I got it out just now. I did dig a bit
but it does not look too bad. The new race is about 1/2 again thicker than the old one, so hopefully it will be OK.
Now that one is out of the way, I need to find something that can slide up the stem housing to hit the upper one with even force. A big socket comes to mind, and I saw those "axle nut sockets" at the parts store, but I hate to spend $15 on something I may use once in a blue moon. Hmmm, maybe the neighbor kid has one of the appropriate diameter I could borrow? :evil:
I am eying my 15" clamps (for woodworking) as possible presses for the new ones....
Jim
- Biquetoast
26 Jan 2007 18:23
EsaPro wrote:
If I remember, I used about an 18" piece of steel pipe for the races (to go through the headstock), and a rod for the wheel bearings...
What I do is go to the local hardware store and buy a section of steel rod or pipe to cut and keep around for just such things....I need to find something that can slide up the stem housing to hit the upper one with even force....
kz750twins.com
kz750twins.com
- fatkow
26 Jan 2007 18:52
Must be the day 4 steering stem bearings I just installed mine 2 day on project - 79 - 1000. it was a breez this time but in the past its bin a real pain.
- EsaPro
26 Jan 2007 18:55:Looks down at grease-stained, aching hands - remembering that he has one more race to drive out::it was a breez this time
I don't wanna hear how easy it was!!!!!!
:lol:
Jim
