swingarm progress pics,need some info
  • wireman
  • wireman's Avatar Topic Author
24 Nov 2006 13:55
#94583
well gotta wait for daughter or genius as she likes to be called to resize them for me!:blush: :P meanwhile does anyone know the diameter of the shock bolt holes on a gs1100 suzuki swingarm and the distance from center of bolt hole to outside edge of swingarm so i can drill my shock mounting bolt holes?:whistle: :Pive got one sitting in arkansas but the ol man is in arizona by now im sure so i dont have access to dimensions i need!
Post edited by: wireman, at: 2006/11/24 16:59:P
Post edited by: wireman, at: 2006/11/24 17:55
  • wireman
Re: swingarm progress pics,need some info
24 Nov 2006 16:19
#94632
still have to cut slots in top of swingarm so the extensions will slide in but i need to drill shock mounting holes and radius extensions around the bolt holes.this will be about 4"over stock compared to a stock kz arm nitrous bottle mount will be built into front of arm where mono shock used to go;)
Post edited by: wireman, at: 2006/11/24 19:31
  • wireman
24 Nov 2006 16:20
#94633
the slot for axle bolt is also raised 1/2"higher than a stock arm to lower bike even more than just short shocks,can ya sap in the weeds boys?:evil: :P
Post edited by: wireman, at: 2006/11/24 19:54
  • wireman
24 Nov 2006 16:21
#94634
extensions will go into frame all the way to the vertical line so it will basically be one big chunk of billet t-6 aluminum from 3" inside arm to 3" outside arm now if i can just scrape up a undrilled stock kz1000 rear rotor and have outside diameter turned down so i can use a gsxr upside down caliper and bracket on back of bike!:evil: :P
Post edited by: wireman, at: 2006/11/24 19:38 the extensions will be flush with bottem and inside/outside will extend through top of swingarm about 3/4" for suzuki style shock mounts.
Post edited by: wireman, at: 2006/11/24 20:12
  • 77KZ650
  • 77KZ650's Avatar
24 Nov 2006 21:20
#94718
I cant help with the mounts, but those look nice, I take it you made them. how hard was that?
Scott
07 MDP Rookie of the Year
  • bob_z1
  • bob_z1's Avatar
24 Nov 2006 21:24
#94721
no slacking off on this project, we want to see pics of the completed arm ASAP......
:laugh:
  • kyradawg
  • kyradawg's Avatar
24 Nov 2006 21:33
#94723
Neato!
Peace&Love:cheer: , Darren
  • wireman
24 Nov 2006 21:34
#94725
Scott
my engine builder milled them out for me i get to engineer(oh yeah here it comes!:P )and design everything then once they are welded on i get to spend far too many hours filing and blocksanding every square inch of it till it looks like one big shiny chunk of billet aluminum!people will have a hard time figuring out what started as when its done ;)
  • spinalator
  • spinalator's Avatar
24 Nov 2006 22:35
#94732
  • wireman
25 Nov 2006 08:33
#94780
i need the shock mount dimensions for a gs1100E 82-83 .i need bolt diameter and distance from center of bolt to outside edge of swingarm to make sure clevis shocks will clear before i can weld these in. ;)
  • spinalator
25 Nov 2006 18:04
#94903
I emailed a very smart racer at old skool suzuki, she is into drag racing machinery with suzuki on the side, but mainly the GSX-R not the GS. She is very knowledgable and will help you more than you deserve. Please hold.... B)
  • wireman
25 Nov 2006 18:07
#94906
cool,thank you sir!;)
