heated handle bars
- xstreamcanadian
heated handle bars
16 Nov 2006 19:22
anybody installed the kit? good bad or am I just a pussy for thinking of it even....
- wireman
- The Milkman
Re: heated handle bars
16 Nov 2006 19:33
I've never seen the kit, where did you find it. Heated gloves may be simpler.
Ride safe,
Les
Ride safe,
Les
- kwakagoose
- xstreamcanadian
16 Nov 2006 20:08
here the kit is at canadian tire that i saw, it is simple enough, you run power to it and the resistance in the loop heats it up, it wraps around the bars under the grip, its pretty cold here at times, especially at high speed, i work with a guy who rides a harley and he goes on epic rides every weekend, he has a plug in for his electric vest, a heated seat and bars..... no HE is a pussy, but a warm pussy and usually a warm one is a good one(sorry steell you may want to edit that out!)
- KZDon
16 Nov 2006 22:15
It's the Canadian Tire kit for snowmobiles for about $30.00. I have one. I haven't installed it. Since then a fine colleague donated an electric vest and gloves. Another colleagus rides his 650Vstrom with heated grips and complains of icy knuckles. As soon as I sort out the wiring, I'm thinking the gloves will be a better solution. The vest is incredible, by the way.
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
2004 650 V-Strom
- geerbangr
16 Nov 2006 23:33
A couple squirts of Chivas Regal keeps my entire body warmed up for a chilly ride . :whistle:
:woohoo: :woohoo: :woohoo: :woohoo:
1978 KZ 1000
I go by Jason
I go by Jason
- flht1997
17 Nov 2006 06:09
i have a cheap kit on my BMW, and no you are not a sissy for wanting them. i think if you use them once a year you will thank your stars that you have them.
i bought a cheap snowmobile kit off from ebay, think it was 25 dollars or so. it had little bulbs (look like co2 cartridge) you slide into the end of the handle bars wrap in insulaton. wire it up, 2 position switch hot and G-D hot!!
if you can get a cheap reliable kit, i ithink they are well worth it.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Pterosaur
17 Nov 2006 07:51
Why would anybody think having a set of toasty mits would anything but a good idea?
The only issue I can see is that along about the time I think I'd need a set, I'd be more concerned with things like tire adhesion/road surface/debris collection. We've already had one guy (Shoe48) taken down by leaves in his path.
Other than that - staying warm is *never* a bad idea...
- Mikes82KZ1100
17 Nov 2006 08:29
I got mine from California Sport Touring Inc
tinyurl.com/8fdgs
- xstreamcanadian
19 Nov 2006 10:05
thanks for all of the replies. The kit I was going to get in my crappy tire says its a motorcycle kit, but I suspect that you guys are correct that it is good for snow mobiles etc, it looks pretty cheap. I was thinking of mounting a toggle under the tank somewhere and hiding the wiring inside the bars, i hate extra wires hanging all over the place.
also, I see from the kink ab0ove that one draws 3 amps, has anyone noticed a dull headlight with throwing that much current to your handlebars?
Post edited by: xstreamcanadian, at: 2006/11/19 13:07
- KZ_Rage
- Kentucky Bourbon Barrel Ale
19 Nov 2006 14:13
Heated bars/grips never made sense to me. You have gloves on which prevent you from getting the most of the heat transfer from the bar/grip not to mention the wind going by is heat sinking off as much of the heat as possible.
I'd go with heated gloves and see how that feels.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
