heated handle bars
- Mikes82KZ1100
Re: heated handle bars
20 Nov 2006 06:46
xstreamcanadian wrote:
Not me but about the only time it's set to high is for the first minute or so for a quick warm up then it's switched to low.I see from the kink ab0ove that one draws 3 amps, has anyone noticed a dull headlight with throwing that much current to your handlebars?<br><br>Post edited by: xstreamcanadian, at: 2006/11/19 13:07
- spinalator
20 Nov 2006 08:19
I have done this mod on 4 bikes and there are a few different ways of going about it.
1.) Kimpex Unit. Cheapest, but throttle hand gets warmer than the other hand unless you insulate the other grip a little. The 3 way switch is big and cheesy, as it was meant for a quad or snowmobile. Cdn tier has them for about 20 bucks. I use the elements and then toggles from radio shack or whatever the hell they are called these days.
2.) dual stars. $$$ but very nice, as Borat would say. Aerostich has a set too but haven't looked at them.
3.) Hot Grips. I havent used in a while but they were a full sleeve that replaced your stock grips. Hard rubber and not my cup of tea. I like the kimpex coz they use the grips you like.
4.) Combo #4. Kimpex elements and switches from dual stars. Computer controlled heat, both hands are same temperature.
www.dual-star.com/index2/Rider/heated_grip_kit1.htm
www.hotgrips.com/
search.aerostich.com/search?ie=&site=my_...tatic&q=heated+grips
news.motorcycle.com/article.motml?thold=...lat&order=0&sid=2538
www.hotgrips.com/
