Help!! Tapered Steering Bearing Install
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
02 Oct 2006 17:10
#81277
OK, I guess my memory is much worse than I thought! I am reinstalling new tapered steering bearings into my frame and I can't remember how far to seat the lower bearing cup. The top cup seats on the inner shoulder and matches up with the very top of the steering neck, but the lower cup is smaller than the lower part of the neck. Do I need to seat the cup fully onto the lower shoulder or just install it until is is flush with the bottom of the neck?? :S I have attached a picture and you can see the space.
I don't remember how the old one was installed...maybe the lower cup should be wider?? Any help would be greatly appreciated. I'm stopped dead in my tracks...
Thanks!
Post edited by: 79MKII, at: 2006/10/02 20:14
The Kaw List:
  • 79MKII
  • Love Them Kaws!
Re: Help!! Tapered Steering Bearing Install
02 Oct 2006 17:16
#81279
Here's a shot of the top cup. It seats on the inner shoulder and sits flush with the neck.
The Kaw List:
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
02 Oct 2006 17:47
#81293
Look at it this way: if you don't seat it up in as far as it goes (to the stop), it will slowly seat itself anyway *while you ride*.... ;)
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
  • steell
  • steell's Avatar
02 Oct 2006 17:53
#81298
And make for a "Real" interesting ride :D
  • loudhvx
  • loudhvx's Avatar
02 Oct 2006 23:33
#81357
You'll have to pull out wrenches everytime you hit a bump.
  • wireman
  • wireman's Avatar
03 Oct 2006 01:45
#81359
dont feel bad,skipper76 put 75 miles on his bike and forgot to put lower race in and thought it handled great!:S after i installed lower race and rebuilt his forks he says it handles a lot better!:P
  • 79MKII
  • Love Them Kaws!
03 Oct 2006 14:23
#81529
I guess my main concern is if the lower race is correct for my bike or not. It seems that it will seat when the steering stem is tightened (or when ridden as has been pointed out :P ) but I don't know that it won't go in too far and allow the lower fork clamp to hit the bottom of the steering neck. I double checked the bearing kit part number and it lists all KZ1000 77-80, so it seems to be correct.
I'd rather drive it all the way in with a bearing driver if that's where it goes so I don't stress the bearings so much when I seat them by tightening the stem. Any thoughts???
The Kaw List:
  • Biquetoast
03 Oct 2006 15:32
#81562
79MKII wrote:
....I'd rather drive it all the way in with a bearing driver if that's where it goes so I don't stress the bearings so much when I seat them by tightening the stem. Any thoughts???
Agreed! By the way, I was kidding in the post above....
kz750twins.com
  • loudhvx
  • loudhvx's Avatar
03 Oct 2006 23:58
#81694
Are you sure you don't have the top bearing and bottom bearing swapped? I suppose they are probably different diameters so there's no way to accidently swap them.
  • jimmybon
  • jimmybon's Avatar
04 Oct 2006 05:30
#81717
I think the lower outer race should be seated to the shoulder, or what could be called, rammed home. Then after assembly with water resistant greese only tighten the lock nut buy hand with a rag and soft hammer. Use the rag for grip round the lock nut and tap the bottom tree just a little
With the front of the bike jacked up, feel the play by grabing the fork bottoms at the bottom then push back and in, if it don't move then its home
tapper roller bearings will disfigure with too much tightening
DONT FORGET THE BOTTOM SEAL below the inner bottom race:ohmy:
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • OKC_Kent
  • OKC_Kent's Avatar
04 Oct 2006 07:22
#81738
Can you put the rubber seal back on? Maybe on the 1000, but on the 650's I didn't, and someone else couldn't find a way to make it fit either.
Here;s a link when I tried it
Good luck whichever way it works out for you.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • 79MKII
  • Love Them Kaws!
04 Oct 2006 09:15
#81762
Thanks for the advice Jimmybon. The diameters are different, so they can't be swapped. It's mainly just the width that I'm worried about, but everything I've seen says it's correct. I think I'll seat the lower outer race and see what happens :S
Now, about the lower seal - I thought that was settled in several other posts (not to use it with tapered bearings). Now you've gone and opened up another can of worms... :ohmy: :P
BTW, Am I correct in assuming that I should pack these bearings before installing? Tapered bearing aren't any different from roller bearings in this respect, right?
Post edited by: 79MKII, at: 2006/10/04 12:21
The Kaw List:
