Front master cylinder
  • Formula264
  • Formula264's Avatar Topic Author
22 Oct 2025 09:59
#918266
Will a stock 78 KZ 1000 master cylinder operate the 6 piston Tokico front brakes ? I have the ZRX master cylinder/lever which will make running the lines much easier but I don't know how I will match the clutch lever, if that makes sense. If I could just use the KZ master it wouldn't be a problem.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Front master cylinder
22 Oct 2025 11:10
#918268
I doubt that the original will displace enough fluid for the Tokico's to have any kind of "feel" (I am using a ZRX unit but I have converted to hydraulic clutch so have a matching clutch master) Maybe you can find a clutch perch from a later model that better matches to the ZRX lever ??
The following user(s) said Thank You: Formula264
  • StreetfighterKz
  • StreetfighterKz's Avatar
22 Oct 2025 13:20
#918270
Check the bores of both M/C’s.  If the Kz is for dual rotors then it should be 5/8”.  IIRC, the Zrx is also 5/8”.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • TexasKZ
  • TexasKZ's Avatar
22 Oct 2025 15:18
#918276
Some of the ZRX guys are running 14mm masters with the six pot calipers. It makes for a little more lever travel, but one-finger stoppies are possible.
  • TexasKZ
  • TexasKZ's Avatar
22 Oct 2025 15:22 - 22 Oct 2025 15:22
#918277
P.S. I have a 14mm master cylinder on my ZRX, but I am using some Nissin 4-piston calipers. As I recall, thee Nissins have slightly more piston surface than the Tokicos.
Last edit: 22 Oct 2025 15:22 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
22 Oct 2025 15:24
#918278
Wooden feel is one of the complaints some of the ZRX folk have about the stock 5/8 master cylinder!
The following user(s) said Thank You: Wookie58, Formula264
  • TexasKZ
  • TexasKZ's Avatar
22 Oct 2025 15:31
#918279
When you get ready to rebuild the calipers, use Hyabusa parts. The calipers and seals are identical, and the 'busa pistons are aluminum, so they are lighter and rust free. Suzuki sells seal kits for each caliper, while Kawasaki sells every single part separately. Suzuki sells the parts for a fraction of the price Kawasaki charges.
The following user(s) said Thank You: rstnick, slmjim+Z1BEBE, Formula264
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Oct 2025 01:17
#918303
What was the donor of your callipers ? all Kawasaki fitments are the same seal kits with the exception of "pre-2000" ZX6R. The early ZX6R has equal sized pistons, all the rest are staggered
The following user(s) said Thank You: TexasKZ
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Oct 2025 02:06
#918304
If you chose to go with the ZRX or a 14mm master (EX500 etc) the below is an idea for a clutch perch that would match :)
  • TexasKZ
  • TexasKZ's Avatar
23 Oct 2025 19:57
#918329
Th
  • TexasKZ
  • TexasKZ's Avatar
23 Oct 2025 19:58
#918330
They were the factory installed calipers on my ZRX.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
24 Oct 2025 00:14
#918333
My bad - in my head I was thinking OP's parts but replying to your post
