Any tanks from other bike that fit on KZ750E frame?
  • H1Vindicator
  • H1Vindicator's Avatar
Re: Any tanks from other bike that fit on KZ750E frame?
18 Aug 2025 05:32
#916174
the mounting bolt on the N/F shaft drive models is perpendicular to the frame. the H is parallel. but they attach basically the same and all use the same bolt, collar, and damper. it might be that the shaft drive rear tank mount could be bent to match the chain drive. partzilla drawings and ebaayy photos. tank length could be an issue. but if the same fuel capacity, then this might work.
