Any tanks from other bike that fit on KZ750E frame?
- JadeDaRocker
16 Aug 2025 13:26
Was doing some rust removal and found a hole in my tank, would it be better to weld some metal on to it or try to find a different tank?
1982 Kawasaki KZ750 LTD
Re: Any tanks from other bike that fit on KZ750E frame?
16 Aug 2025 13:34Depends how bad it is (the area around the hole is likely to be thin from corrosion on the inside) if it's still solid it might be better to "braze" the hole. You can use a pin punch to create a dent where the hole is so that you can get some brass on there (if not the brass will only be filling the hole and could drop out)Was doing some rust removal and found a hole in my tank, would it be better to weld some metal on to it or try to find a different tank?
- JadeDaRocker
16 Aug 2025 13:37
with how bad the inside is, im thinking that that wouldnt work
16 Aug 2025 14:02 - 16 Aug 2025 14:06Is this for the bike in your avatar (looks like a "KZ750H" not an "E" as per the thread title ? I believe somebody else here put an "E" tank on a "H" but if I remember it wasn't straightforward (had to change the triples etc as the forks were hitting the "E" tank)with how bad the inside is, im thinking that that wouldnt work
Last edit: 16 Aug 2025 14:06 by Wookie58.
- JadeDaRocker
16 Aug 2025 14:21
The identifier would be the vin correct?
16 Aug 2025 14:35Indeed it wouldThe identifier would be the vin correct?
- JadeDaRocker
16 Aug 2025 14:38
Well then all the guns on the bike say KZ750E
16 Aug 2025 14:50Not trying to be a dick, just trying to help you so you don't order/buy parts for the wrong bike (your signature says it's a Ltd)Well then all the guns on the bike say KZ750E
- JadeDaRocker
16 Aug 2025 17:23
The H3 in the pics is what I have, I'm just really confused then, thank you
- StreetfighterKz
16 Aug 2025 18:33
This may be a needless question, but are you looking at the engine number and not the frame number on the steering neck?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- H1Vindicator
17 Aug 2025 08:28
if it's a 750H Ltd. then any of those should physically fit. 1980-83. plus the 81-83 650H CSR which have the same frame. caution: pay attention to the location of the petcock bung. on some tanks it's more rearward. if not the same as yours, the petcock may contact the carburetor. possible fix for that is a different petcock or fuel valve. one that's more squat. yamaha has some. but then petcock bolt hole spacing is another consideration.
The following user(s) said Thank You: JadeDaRocker
17 Aug 2025 11:28
LTD tanks are way easier to find than E tanks. The confusion comes in though, because Kawasaki made N models, F models, H, and maybe others that were basically LTD type. I'm not sure, but I suspect some are similar, but how to know? And what I mean, are some mount the same, have the petcock in the same place, but again, how to know?
