KZ440 fork cap removal
  • Sdaniels2010
  • Sdaniels2010's Avatar Topic Author
Re: KZ440 fork cap removal
07 May 2022 15:32
#866752
I'm wondering if anyone has replaced the circlip with a snap ring?
I don't think the snap ring would be secure.
I believe the groove in the fork tube is round to fit the round clip, and also the cap has a bevel on the top edge to capture the clip.  That's why you need to push the cap down to reveal the clip.  At least that's how it was on the gpz550 I worked that had a similar setup.
The snap ring certainly wouldn't be captured by the cap, and I suspect the square edge of the snap ring would not hold on to the groove in the fork tube very well.
Noted...I'll leave this alone.  My son is a mechanical engineer but I'm not so I'll defer to Kawasaki's finest.
1981 KZ440 A2 LTD
  • martin_csr
  • martin_csr's Avatar
08 May 2022 09:09 - 08 May 2022 09:10
#866779
or remove the circlip the way F64 says.
Last edit: 08 May 2022 09:10 by martin_csr.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 May 2022 14:14
#866786
I completely agree and F64's method should work fine, it's just as I get older I like things to be controlled and less of a fight hence the suggestion of the puller since it's not a lot of money
  • Sdaniels2010
08 May 2022 16:34
#866792
I like your method, dude!  It lets you separate pushing down the cap & removing the circlip instead of trying to do both at the same time....thought it was very clever
1981 KZ440 A2 LTD
  • Mikaw
  • Mikaw's Avatar
08 May 2022 17:46
#866793
Could you use a "two legged " puller hooked under the tree to hold the plug down while you concentrate on the clip (would also allow you to release the spring in a controlled way) could also be used to compress the spring for re-assembly ? Something like this
Solid idea!
  • Sdaniels2010
16 May 2022 15:42
#867175
Well I finally got those jokers removed with the help of my wife...I'm giving serious thought to taking those tubes to a machine shop & having threads cut.  Man was that aggravating!
1981 KZ440 A2 LTD
