Are front drum brakes really that bad?
  • Ian_B
  • Ian_B's Avatar
Re: Are front drum brakes really that bad?
02 May 2022 00:08
#866520
Twin leading shoe? How about 4 leading shoe:
Same issues with cooling on repeated stops though. There was a comment about wet drum brakes - are these any worse than the Z1000 I had with stainless front discs? When wet, zero braking, then sudden wheel lock. Awful things.
For normal road use, either is capable of doing the job. But the preference now is for discs. Cheaper to manufacture and lighter.
Ian
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
02 May 2022 00:39
#866522
That thing is huge
  • TexasKZ
  • TexasKZ's Avatar
02 May 2022 04:30
#866526
Ian
Cool for sure, but what a pain to keep adjsted.
  • Ian_B
  • Ian_B's Avatar
03 May 2022 02:41
#866580
Keeping it adjusted - yes, that was my first thought; one of the 4 shoes will always come on first, yes? But look closely at the pulling points - there's a balancing piece that ensures that the front & rear pairs get pulled equally hard. You'll still need to adjust teh front 2 spindles and the back 2 spindles, but I suppose it halves the work.
No wonder twin hydraulic discs became popular :)
  • Ian_B
  • Ian_B's Avatar
03 May 2022 08:10
#866586
The other interesting thing about this particular one are the spoke holes - it looks like th edrum can be laced into pretty much any rim. It probably cost so much that you'd want to take it with you from one bike to the next...
