Spectre - Rear axle - Castle nut stuck
  • McThing
  • McThing's Avatar Topic Author
01 Feb 2022 16:57
#861618
Hi all,
The castle nut on my real axle will not come free. I’ve tried saturating it repeatedly in Wd40 for 24 hours, heat, and gentle but firm raps with a hammer. I am using a 24” break but it just turns the whole axle and anything I stick in the hole on the opposite end of the axle to brace it just bends like butter.
I have seen on YouTube where someone just cut into the nut and hit the gap with chisel to break it loose. Before I go that far I thought I’d check and see if anyone had a better idea.
All the best - B
1983 KZ750N2 Spectre
Baltimore, Maryland - USA
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Spectre - Rear axle - Castle nut stuck
01 Feb 2022 17:30
#861620
Does the opposite end of the axle have flats machined into the head?  That's true for the earlier models.  I use a big crescent wrench to hold the axle when torquing it.
My dad's '74 Z1
'00 ZRX1100
  • McThing
01 Feb 2022 17:31
#861621
Nope. No flats. Dang.
  • DOHC
  • DOHC's Avatar
01 Feb 2022 17:37 - 01 Feb 2022 17:39
#861622
Yeah, I was looking around eBay and it looks perfectly round.  That was an odd choice for Kawasaki.
I would probably just grab the head with a big pair of vise grips and then once I got it off replace it with an earlier or later model axle with a proper head.  Or grinds flat spots into that one for next time.  :)
I'm guessing it's like this?
My dad's '74 Z1
'00 ZRX1100
Last edit: 01 Feb 2022 17:39 by DOHC.
The following user(s) said Thank You: McThing
  • Ojisan rider
  • Ojisan rider's Avatar
01 Feb 2022 18:04
#861623
How long have you been heating the nut? Sometime, you need to use it longer than usual. I know you need to worry about the oil and dust seal, but getting the nut off will be priority, I think. Tried MAP gas?
It was on metal to metal, but I once had to heat up tie rod about 5 minutes before I could turn and get that thing off...............BTW, I used regular hand-held propane torch for that.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • H1Vindicator
  • H1Vindicator's Avatar
02 Feb 2022 07:08 - 02 Feb 2022 07:18
#861647
parts diagrams show both types of axles for the 750n Spectre. so maybe look into getting the axle w the hex head. as for the current problem, does the oem tool kit have a bar or screwdriver bit that fits the axle hole? my tool kit doesn't have anything, so I use a big hf screwdriver for the fr axle. rear axle has hex head.
Last edit: 02 Feb 2022 07:18 by H1Vindicator.
  • Mikaw
  • Mikaw's Avatar
02 Feb 2022 07:26
#861650
Put a pipe wrench on the axle bolt head.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
02 Feb 2022 08:29
#861656
I would suggest something other than WD40.  But what do I know?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • scubaanders
  • scubaanders's Avatar
02 Feb 2022 08:52
#861658
For penetrating oil, try first cleaning with Brake clean and the soak in a mix of ATF oil and Acetone 50/50.
add a couple of times per day then try again.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • H1Vindicator
02 Feb 2022 09:04 - 02 Feb 2022 10:13
#861663
nowadays, he may be using wd40 penetrant instead of reg wd40. could use kroil or liq wrench. lw is cheaper & available at a lot of places.
Last edit: 02 Feb 2022 10:13 by H1Vindicator.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
02 Feb 2022 10:29
#861669
Try to file or grind the nut as flat/thin as possible next to the axle diameter. This will weaken the nut and remove the tention and binding on the threads.
Heating up the flat/thin part will penetrade more heat and stretch to the nut/thread expanding. A good wack with a chisel should the nut turn loose or break the thin part open.
02 Feb 2022 10:30
#861670
Try Kroil.
