Brake Squeak
  • dancragin
  • dancragin's Avatar Topic Author
Brake Squeak
03 Dec 2021 13:31 - 03 Dec 2021 13:32
#858571
1976 Z900 A4
Dual disc brakes/ Factory
I've tried everything to keep the brakes from squeaking. Two sets of new organic pads. Chamfered the edges, added the anti rattle plates, resurfaced the rotors,
even tried the automotive pad anti squeak spray.
As soon as the pads are run in. They squeak.
Any ideas?
Last edit: 03 Dec 2021 13:32 by dancragin.
Re: Brake Squeak
03 Dec 2021 14:31
#858572
The front pads on my 1977 KZ650-C1 squeaked when I installed non-Kawasaki pads.  I did a number of things to eliminate the noise, but is always came back - and it was loud.  I installed genuine Kawasaki pads and the squeak disappeared.  Ed
  • Rick H.
  • Rick H.'s Avatar
Re: Brake Squeak
03 Dec 2021 16:54
#858578
As 650ed stated, the best option is to run OEM pads and bed them in properly.  Aftermarket pads can be filled with grief at times.  How was resurfacing of the rotors accomplished?  Make sure that the piston(s) retract to eliminate as much rotor drag as possible and make sure to lube contact points.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • bluej58
  • bluej58's Avatar
Re: Brake Squeak
03 Dec 2021 17:00 - 03 Dec 2021 17:14
#858579
For me, it seems like every time I go down  dusty roads my front brakes squeal.
My fix;   I  squeeze the front brake hard (At a stop )  and give her some gas then ease up on  the brake enough to let the wheel turn and roll for about 20 feet under pressure.
That usually is enough to stop the squeak, if that doesn't work I hand sand the disks with 400 grit by pressing the sand paper to the disk  and spinning the wheel a few times.
Can't remember what brand pads they are.
78 KZ1000 A2A
Last edit: 03 Dec 2021 17:14 by bluej58.
  • 750 R1
  • 750 R1's Avatar
Re: Brake Squeak
04 Dec 2021 00:03
#858585
The squeal has nothing to do with the pads, its caused by a resonant frequency from the pads moving at a high speed, that's why a lot of bikes have a piece of spring steel behind the pad, put a dab of silicone on the centre of the back of the pads or some brake grease, keeping everything clean helps as well.....
Google "how to stop motorcycle pads squealing" and have a read....
  • Rick H.
  • Rick H.'s Avatar
Re: Brake Squeak
05 Dec 2021 09:08
#858636
Well now I am once again confused.  For the last 50 years or so I was told under most circumstances in normal usage it was best to always use OEM brake pads and linings to help keep noise issues at bay.  Is this not the case?  If so, I have wasted a lot of money.
Rick H.
Rick H.
  • 750 R1
  • 750 R1's Avatar
Re: Brake Squeak
05 Dec 2021 13:53
#858650
Rick H.
I have never bought OEM brake pads in 40 odd years of riding, I've see both OEM and aftermarket pads squeal, never had squealing pads on any of my bikes...
  • Mikaw
  • Mikaw's Avatar
Re: Brake Squeak
05 Dec 2021 15:53
#858652
750 R1, are you saying to add a dab of silicone just in the center. That stops the frequency. Or are you coating the entire back side of the pad to isolate it from the piston. Which side cause the squeal? The piston or fixed.
  • 750 R1
  • 750 R1's Avatar
Re: Brake Squeak
06 Dec 2021 02:22 - 06 Dec 2021 02:23
#858674
The pads are basically vibrating, anything that dampens the vibrations will stop the squeal. There are specialised silicone product to use, Years ago I used high temp silicone, spread around the piston to pad contact point, now you can use products like the one in this video.   Watch the whole video, he covers it well.
Last edit: 06 Dec 2021 02:23 by 750 R1.
  • dancragin
Re: Brake Squeak
08 Dec 2021 12:40
#858828
I just ordered some OE pads and new anti rattle clips. I've had the rotors resurfaced by a company that specializes in motorcycle rotors. They have a machine that grinds them flat.
  • Mikaw
  • Mikaw's Avatar
Re: Brake Squeak
08 Dec 2021 15:40
#858838
Truedisk?
  • Nessism
  • Nessism's Avatar
Re: Brake Squeak
08 Dec 2021 15:53
#858839
The old style round puck brake pads tend to squeak more so than the later type calipers.  I don't know why, but that's been my experience.
