Brake Squeak
  • martin_csr
  • martin_csr's Avatar
Re: Brake Squeak
09 Dec 2021 06:00 - 10 Dec 2021 05:18
#858856
By 750R1:  .... There are specialized silicone product to use
I use brake caliper grease. Permatex Ultra in the little packets. technical data sheet says to use it to prevent brake squeal.
Last edit: 10 Dec 2021 05:18 by martin_csr.
The following user(s) said Thank You: bluej58, 750 R1
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Brake Squeak
09 Dec 2021 23:52
#858892
Z1s are notorious for squeaking brakes without oem pads.  The adhesive only lasts a few hundred miles, shims should help.  Havent had the ambition to do mine yet.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
