Fork rebuild
  • Elfarm98648
  • Elfarm98648's Avatar Topic Author
Fork rebuild
29 Aug 2021 12:32
#854521
Hello all, I have my right hand side fork leaking so it’s time for a rebuild. I see on the z1 enterprises page they list the top dust cover, one seal below that, a bolt, and a copper washer. Is there anything else that I need more than this? What kind of oil do you all use for your forks? What PSI should the forks be placed at?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Fork rebuild
29 Aug 2021 14:19
#854529
Some are easy some are not.
  • Nessism
  • Nessism's Avatar
Re: Fork rebuild
29 Aug 2021 14:56
#854534
The oil spec is in the factory Kawasaki manual for your bike.  If you don't have one there are a lot of manuals for free download here in the Articles tab at the top of the forum.  For most KZ's 10 or 15 weight oil is appropriate.  In term of air pressure, the best answer is zero psi.  Get some new fork springs from Sonic and ditch the air.  The forks will ride better with less seal stiction.
