1974 Z1 Master Cylinder Reassembly
Re: 1974 Z1 Master Cylinder Reassembly
18 Jun 2021 08:04 - 18 Jun 2021 08:05
Aslo make sure the eccentric adjuster bolt is not threaded in to deep. Install it without the lever. Eyeball to make sure you have no threads showing in the slot where the lever lives. If it’s threaded in to deep the lever hits the bolt and not the eccentric stem. You loose all of the adjustments.
Last edit: 18 Jun 2021 08:05 by Mikaw.
- DOHC
- Those Doe-Hawks really go!
18 Jun 2021 13:24Look at that! I'll assume the cause was that my dad was up to some shenanigans, and then cleaned it up with some careful reshaping and a bit of filler. Unfortunately the details of that story will forever remain a mystery.Mikaw post=850359That’s road rash. The casting should be more pointed.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
