VIN sticker, does it have to be there?
  • katit
  • katit's Avatar Topic Author
11 Mar 2021 14:07
#844778
In preparation to frame refinish. I am not sure what to do with sticker. VIN number also on a frame. But this white sticker with model info is starting to peel a little.
Will it survive powdercoat oven? Any tips on keeping it and masking around?
Does it really have to be there or just VIN in metal will be fine?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: VIN sticker, does it have to be there?
11 Mar 2021 15:12
#844782
katit wrote: In preparation to frame refinish. I am not sure what to do with sticker. VIN number also on a frame. But this white sticker with model info is starting to peel a little.
Typically stamped VIN is enough
But One of our members makes new ones if needed..
Powdercoat oven will cook it
  • katit
11 Mar 2021 15:16
#844783
Dave, who makes them? I think I want one just so it's there
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Mar 2021 01:11
#844804
PM member Kidkawie
kzrider.com/forum/5-chassis/600192-repro...cker?start=12#770527
The following user(s) said Thank You: katit
  • katit
17 Mar 2021 08:15
#845066
Any other sources for stickers? Can't get a hold of Kidkawie
  • hardrockminer
  • hardrockminer's Avatar
17 Mar 2021 08:24
#845069
You can try Rick Brett on Facebook.
  • z1kzonly
  • z1kzonly's Avatar
17 Mar 2021 10:29
#845081
I should know better! But I have a hybrid dragbike I purchased 1 yr. ago. That has a 1977 KZTOOA title. I need to clean up frame with no numbers, then ad them.
The numbers are on the left side of frame? Dyno side. As The Z1, KZ, Z1F as usual? Just checkin'
Thanks.
  • ronnieV
  • ronnieV's Avatar
17 Mar 2021 10:53
#845084
There's also a seller in ebay that reproduce them with your vin number.I ordered one and was satisfied.
  • katit
17 Mar 2021 11:34
#845087
do you remember sellers id?
  • katit
17 Mar 2021 11:46
#845088
No eBay APP ID and/or Cert ID defined in Kunena configurationOk guys, never mind. It is Rick Brett and on eBay !!
17 Mar 2021 13:19
#845091
Interesting!  That sticker is completely different than the original sticker on my 1977 KZ650-C1.  Maybe they changed it in 1978 or maybe the bikes made in the US, like the 1978 one, had a different sticker than those made in Japan like my 1977.  Ed
  • katit
17 Mar 2021 13:24
#845092
Right. Mine is made in US, hence  a sticker. Here is yours:
