KZ400 fuel tank cap identification
  • fricks
  • fricks's Avatar Topic Author
Re: KZ400 fuel tank cap identification
18 Jan 2021 03:05
#841913
Thank you very much!! If I end up finding something similar I will post a link here so others can find a possible replacement too :)
  • TexasKZ
  • TexasKZ's Avatar
19 Jan 2021 04:12
#841992
The distance between the seal and the top of the locking tabs might also be important.
  • martin_csr
  • martin_csr's Avatar
19 Jan 2021 08:43 - 20 Jan 2021 08:01
#842008
By Nerdy: Right, so I was able to find the key *and* the calipers to take some measurements, so here we go.
overall diameter = 71mm
the black O-ring and the metal bit under it = 55mm
the round piece that goes into the tank - the outcropping at the 12:00 position = 34.5mm (C)
the round piece that goes into the tank + the outcropping = 38mm (D)
the two locking pieces when they're out = 41.5mm (E)
the central piece stamped 'Made in Japan' = 26mm (F) ...
Thanks for the measurements. Does this pic look right?
Last edit: 20 Jan 2021 08:01 by martin_csr.
The following user(s) said Thank You: Nerdy, fricks
  • Nerdy
  • Nerdy's Avatar
19 Jan 2021 14:52
#842037
martin_csr wrote: Thanks for the measurements. Does this pic look right?
It certainly does - thank you! You beat me to it. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: martin_csr
  • Nerdy
  • Nerdy's Avatar
19 Jan 2021 14:53
#842038
TexasKZ wrote: The distance between the seal and the top of the locking tabs might also be important.
That's a good point. I will grab that measurement when I have a chance.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: fricks
  • fricks
08 Feb 2021 12:37
#843180
Hey Nerdy, just checking in to see if you've had an opportunity to measure the distance between seal and locking tabs? Thank you
