KZ400 fuel tank cap identification
- fricks
09 Jan 2021 04:25
Hi, I am hoping someone can help me identify the correct fuel cap I need for my tank.
When I purchased the tank, the seller told me it is from a 1980 KZ400 K4 BJ and it has possibly come from a European bike if that helps.
A lot of the caps I see online operate on a hinge which my tank does not have.
I've attached some photos of the opening in the tank. If anyone could help it would be much appreciated!
Re: KZ400 fuel tank cap identification
09 Jan 2021 06:12 - 09 Jan 2021 06:35
I don't know what fuel cap you would need. The 79 KZ400-B2 has a fuel cap without a hinge, and from the cross-reference at Partzilla about a dozen or so other models used the same one. That style is typically hard to find. There's one on EB that includes an ignition switch & seat lock, but it's expensive. I would check the various KZ400 models at partzilla, then head over to EB. be sure to look at EB pics of fuel tanks.
EB item number: 254819033183. pricy set mentioned above.
EB item number: 264951740697. completed listing. Thailand.
ps: paint looks like a pretty color. did you use a polyurethane clear coat?
Last edit: 09 Jan 2021 06:35 by martin_csr.
- Nerdy
09 Jan 2021 10:11
Something like this I think:
www.cmsnl.com/kawasaki-kz400b2-1979-cana...#pageproductModelfit
That's not your exact model of KZ400 but the 'model fit' list contains Euro bikes.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- fricks
10 Jan 2021 01:28martin_csr wrote: I don't know what fuel cap you would need. The 79 KZ400-B2 has a fuel cap without a hinge, and from the cross-reference at Partzilla about a dozen or so other models used the same one. That style is typically hard to find. There's one on EB that includes an ignition switch & seat lock, but it's expensive. I would check the various KZ400 models at partzilla, then head over to EB. be sure to look at EB pics of fuel tanks.
Thank you! Apologies, what is "EB"? I am not 100% sure about the clear coat, I haven't painted it myself. I assumed it may have been a factory colour?
- fricks
10 Jan 2021 01:30Nerdy wrote: Something like this I think: www.cmsnl.com/kawasaki-kz400b2-1979-cana...#pageproductModelfit
Thank you - that looks like it could the the one!
10 Jan 2021 10:26 - 10 Jan 2021 10:27
EB = ebay. The one at cmsnl is the same as the EB items. The completed listing out of Thailand is black but otherwise should fit the same. They look the same to my eye.
Last edit: 10 Jan 2021 10:27 by martin_csr.
- Nerdy
10 Jan 2021 20:16fricks wrote: Thank you - that looks like it could the the one!
You're welcome. It's the kind that my KZ400 tanks (US models) had/have, so it should work. If you can find one.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- fricks
12 Jan 2021 00:19
Does anyone have one of these round caps that they could take some measurements from? I am looking at aftermarket options so hoping I can find something close in size! Thank you
- Nerdy
14 Jan 2021 18:48fricks wrote: Does anyone have one of these round caps that they could take some measurements from? I am looking at aftermarket options so hoping I can find something close in size! Thank you
I checked the spares department (aka the basement) and found a KZ400 tank with a round gas cap. If I can find the key I'll pull the cap and take some measurements.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: fricks
14 Jan 2021 20:11Nerdy wrote: I checked the spares department (aka the basement)
Or as Karzee1 calls it. The SOS, stash of sh#t.
- fricks
15 Jan 2021 04:03Nerdy wrote:fricks wrote: Does anyone have one of these round caps that they could take some measurements from? I am looking at aftermarket options so hoping I can find something close in size! Thank you
Champion! Thank you!!
- Nerdy
17 Jan 2021 18:24 - 17 Jan 2021 18:30
Right, so I was able to find the key *and* the calipers to take some measurements, so here we go.
overall diameter = 71mm
the black O-ring and the metal bit under it = 55mm
the round piece that goes into the tank - the outcropping at the 12:00 position = 34.5mm
the round piece that goes into the tank + the outcropping = 38mm
the two locking pieces when they're out = 41.5mm
the central piece stamped 'Made in Japan' = 26mm
Hope that helps
Hope that helps
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
Last edit: 17 Jan 2021 18:30 by Nerdy.
