- Thank you received: 1918
'96-'97 ZX9R swap to '77 Kz1000 LTD Frame
The only reason I had concerns about cutting into the top yoke to create the drop. I had ask Roy if he had a slimmer version of them. He mentioned that the one he linked me to (the one I posted) was the slim one. Just brought up a concern if he is considering it a slim/lighter unit if you remove material it makes it even thinner. I wasn't trying to disparage Roy and his work. I wouldn't have reached out to him in the fist place if I had concerns of his quality. Just a persons objection.
- Bama704
- Thank you received: 28
1977 KZ900
Carbs are late model 1975 28mm
- zed1015
- Thank you received: 1551
Be sure to bore a 3mm hole up the center of the extension to allow the passage of oil for the damping adjuster .Bama704 wrote: Since my zx6r forks are shorter than the zx9 ones my ground clearance is low, but manageable. At some point I will raise it up but in my opinion it is too expensive for a drop top yoke, I will be doing what Zed has done. Will just have to find somebody to make them for me and I will do it when I need to change the fork oil anyways.
- kzstreetfighter71
- Atlantic West Coast
- Thank you received: 250
kzstreetfighter71 wrote: I can take photos and measurements of both if you're interested ?
Lost here who are you offering this to and what are you measuring. Sorry. Thanks for offering to help.
- Thank you received: 797
quite a bit of work for less than an inch. but when your chasing ground clearance that might be the lil bit it takes to keep the header off the ground.
- kzstreetfighter71
Sorry about the confusion, i was just offering a side by side comparison of the trees in material thickness and clamping area if you were interested.
- Thank you received: 2059
Thank you. I have a complete fork and triples from both the Kz1000 LTD and the '96-'97 ZX9R. What I really need is how to measure the drop on the Kz upper yoke, Nessism mentioned its about an inch. I'd like to know how to measure that. Then once I know that then I can measure the clamping points on the ZX9R forks to determine if a drop is also needed on the lower yoke so the clamping point will land on the larger OD as it would on the ZX9R OEM trees.
Thank you. I have a complete fork and triples from both the Kz1000 LTD and the '96-'97 ZX9R. What I really need is how to measure the drop on the Kz upper yoke, Nessism mentioned its about an inch. I'd like to know how to measure that. Then once I know that then I can measure the clamping points on the ZX9R forks to determine if a drop is also needed on the lower yoke so the clamping point will land on the larger OD as it would on the ZX9R OEM trees.[/quote]
to measure the drop of a triple clamp you measure the distance from the bottom of the stem area to the bottom of the fork leg clamping area.so straight edge across the bottom of the clamps at the fork area and measure from the straight edge to the bottom of the clamp where the stem goes through.
hth,
Ducati GT1000. Front is 17 x 3.5 and rear is 17 x 5.5, pretty stoked!
