- Thank you received: 1918
'96-'97 ZX9R swap to '77 Kz1000 LTD Frame
- Thank you received: 2740
Here’s what I’m talking about. I know pictures can distort perspectives and dimensions, but look at the fold in the cardboard. I tried my best to align the top of both uppers with the fold
- zed1015
- Thank you received: 1551
Use the Z stem , press and weld it into the remains of the ZX9 stem that has been cut and machined flush with the top of the bottom yoke.
Use a ZX7R top toke and bore out the hole to take the top of the zed stem.
You don't loose much ground clearance using them as is but if you want a bit more lift you can get an extra 32mm by fitting a simple internal extension to the damper rod.
- zed1015
This is using the shorter ZX7 forks but with the damper rod extension as shown in my last post.
This puts them at the same length as stock ZX9 forks and there's plenty of ground clearance.
This is just to show that you don't need to step the yokes to get decent ground clearance.
- zed1015
I always dry build the complete machine to ensure everything clears etc before stripping it back down for paint etc.
zed1015 wrote: I always dry build the complete machine to ensure everything clears etc before stripping it back down for paint etc.
Another statement that shows I’m not a fabricator. Oops
