KZ 750 twin newbie question
- eddkz750
01 Aug 2020 11:11
Hi, I am having a LOT of trouble getting the front lower engine mount bolt to break free. I have the nut off, but cannot get the bolt to move. I was going to use a torch to heat up either the frame mounts or the engine itself. this is my question. should I heat the frame or the engine?
Any guidance would be appreciated.
Thanks and glad I found kzrider,com
- krazee1
Re: KZ 750 twin newbie question
01 Aug 2020 15:26 - 01 Aug 2020 15:27
Do you have the remaining engine mount fasteners loose? If so you should be able to wiggle the engine a bit and relieve the bind on the bolt you're trying to remove.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Last edit: 01 Aug 2020 15:27 by krazee1.
The following user(s) said Thank You: eddkz750
- DoctoRot
02 Aug 2020 12:23 - 02 Aug 2020 12:25
Use a drift to tap it out, if it still won’t ‘budge hit the cases with some heat. Lots of penetrating oil won’t hurt either.
Last edit: 02 Aug 2020 12:25 by DoctoRot.
02 Aug 2020 13:09 - 02 Aug 2020 13:10eddkz750 wrote: Hi, I am having a LOT of trouble getting the front lower engine mount bolt to break free. I have the nut off, but cannot get the bolt to move. I was going to use a torch to heat up either the frame mounts or the engine itself. this is my question. should I heat the frame or the engine?
Soak it with Kroil for a couple days and it should move without too much difficulty. Ed
Last edit: 02 Aug 2020 13:10 by 650ed.
- eddkz750
03 Aug 2020 06:47
I tried a brass punch and it still would not budge
- eddkz750
03 Aug 2020 06:50
Thank you all for your replies, I have tried a brass punch (still did not move). I will try removing all other bolts and moving the engine to free it up (one day this week).
03 Aug 2020 07:35 - 03 Aug 2020 07:54
Instead of removing all of the other bolts, maybe try just loosening them.
Is the engine blocked or is its full weight still on the frame?
Last edit: 03 Aug 2020 07:54 by martin_csr.
- krazee1
03 Aug 2020 18:44martin_csr wrote: Instead of removing all of the other bolts, maybe try just loosening them.
Good thought! ( see first reply)
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- usa forever
10 Aug 2020 06:44
Seafoam deep creep is an excellent oil to use. I usually let that set for a day or two soak it up again and hit it with a heat gun or a hair dryer we can't do much damage with that and it will create a little wiggle then you can work it back and forth quarter-turn at a time hopefully
