This Doesn't Look Right... Fork bottom Allen bolt on 81 kz650 CSR
- KZ650JAY
11 May 2020 12:14
Hey guys, I was just about to start rebuilding my forks and ran into ran issue. I went to loosen the bottom Allen bolts and this is what I found. Sorry for the bad pictures ill try and get better ones when I remove the forks from the bike.
- F64
- 81-KZ440D2
Re: This Doesn't Look Right... Fork bottom Allen bolt on 81 kz650 CSR
11 May 2020 12:31
doesn't look oem.
martin_csr would know.
martin posted something on those forks last year.
kzrider.com/forum/5-chassis/610541-77-kz650-fork-question
You may just need to file flats into the side and use and open end wrench.
81-KZ440-D2.
LIC, NY
LIC, NY
11 May 2020 16:06 - 12 May 2020 07:39
By F64: doesn't look oem.
Agreed. Looks like somebody installed hex bolts in place of the allen bolts. The bottom allen bolts should be installed with aluminum gaskets. I forget what the manual specifies, but I put a high temp thread sealant on the threads to act as a thread locker.
Just an FYI. There's a pdf manual available for the 81 KZ650.
Last edit: 12 May 2020 07:39 by martin_csr.
The following user(s) said Thank You: KZ650JAY
- KZ650JAY
11 May 2020 16:55
I'm now thinking someone stripped or drilled the Allen head out and rigged these in vs replacing the Allens.... Great
