1980 Z1R rear shock restoration question
  • PaintWorkz
  • PaintWorkz's Avatar Topic Author
03 Apr 2020 09:23
#822536
I am doing a cosmetic restoration on 2 pair of 1978 Z1R and 1 pair of 1980 Z1R rear shocks. The 78 's all have a rubber bumper on the top of the shock rod so it does not bottom out at full compression, but the 1980's did not have the bumper. Did the 1980's come with that bumper? If they did what is a source for the correct looking ones?
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • david richard
  • david richard's Avatar
Re: 1980 Z1R rear shock restoration question
04 Apr 2020 10:12
#822606
hi sorry i cant answer your question ,but can i ask in your refurb have you managed to get some bump stops if so are they 12.5 mm approx inside thanks david
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
04 Apr 2020 12:04 - 04 Apr 2020 12:05
#822611
I would try to look on the Automotiv sector. There are a lot cheap stop rubber bumper avaliable you can use with some modifications, (for example VW Beatle).
Last edit: 04 Apr 2020 12:05 by Scirocco.
The following user(s) said Thank You: david richard
  • PaintWorkz
05 Apr 2020 13:50
#822662
david richard wrote: hi sorry i cant answer your question ,but can i ask in your refurb have you managed to get some bump stops if so are they 12.5 mm approx inside thanks david
Bump stops are 9.90 mm I.D. since the shock shafts are 10 mm O.D. on 78's and 80's
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • PaintWorkz
05 Apr 2020 13:53
#822663
Scirocco wrote: I would try to look on the Automotiv sector. There are a lot cheap stop rubber bumper avaliable you can use with some modifications, (for example VW Beatle).
I would like to find bumpers that look original......but the important question is did they even put them on the 1980 models?
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
05 Apr 2020 14:16
#822664
Any pics of the damper and bumps stops?
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
05 Apr 2020 16:09
#822671
I think that's exactly what he's asking for. Someone else with a 1980 Z1R with original shocks to take some pictures.
My dad's '74 Z1
'00 ZRX1100
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
05 Apr 2020 17:39 - 05 Apr 2020 17:40
#822677
Hi Ralph
Here are some pictures of a members 80 Z1R
It is restored , but I also put in a before picture showing the rear shocks
This is a past BOTM in OZ.
I hope this helps
Last edit: 05 Apr 2020 17:40 by Street Fighter LTD.
  • PaintWorkz
05 Apr 2020 19:37
#822680
Thanks Dave....but the before and after pics are both none OEM shocks
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • Moderator
  • Moderator
05 Apr 2020 20:20
#822682
I will keep digging
  • DOHC
  • DOHC's Avatar
05 Apr 2020 20:26
#822683
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is a sold item that might be from a D3. These also have no bump stop.
My dad's '74 Z1
'00 ZRX1100
  • PaintWorkz
06 Apr 2020 07:45
#822705
Thanks DOHC....I contacted seller ( numbnuts603 ) even though they were sold to ask about bumpers. They looked restored due to color/ finishes.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
