2K paint on the brake disc.
  • gordone
  • gordone's Avatar Topic Author
07 Feb 2020 09:38 - 07 Feb 2020 09:40
#818756
I`m planing to upgrade the brakes (cosmtic).
1. take of the disc brake and have some phosphoric acid to remove the correction outside the zone bere the disc pads is working.
2. Paint the disc brake (out side the brake pads zone) with 2K top coat paint.
3. Use new stainless steel bolt when installing the brake disc again.
I understand the phosphoric acid is making a good base to paint on so will just have 2K clear top coat over.
My question is, will a normal 2K top coat be okay with the temperature on the brake disc?
Project:
Last edit: 07 Feb 2020 09:40 by gordone.
  • martin_csr
  • martin_csr's Avatar
Re: 2K paint on the brake disc.
07 Feb 2020 15:06
#818774
I don't know, but probably not. You'll probably need a high temp product. Eastwood sells a 2k engine paint.
Eastwood 2K AEROSPRAY HIGH TEMP CERAMIC ENGINE PAINT
The following user(s) said Thank You: Nessism, gordone
  • gordone
08 Feb 2020 06:11
#818800
Thank you, have not found it in Noway yet, but have found these:
gasolin.no/bremsegr.html
Is 200 grader celcius = 392 Fahrenheit enougf ?
Project:
  • martin_csr
08 Feb 2020 06:28 - 08 Feb 2020 08:06
#818802
I would clean & polish the disks. not paint. not phosphoric acid.
edit: I wouldn't use phosphoric acid if not painting. phosphoric acid etches the surface, so if you don't paint, it will rust faster & might make the surface look bad before it rusts.
Last edit: 08 Feb 2020 08:06 by martin_csr.
  • gordone
08 Feb 2020 06:35
#818803
martin_csr wrote: I would clean & polish the disks. not paint. not phosphoric acid.
Why not ?
I`m only planing to paint the area where the pads is not working, I was hoping to get almost "maintenance free" disc brake by doing these :)
I sandplasted the disc 2 years ago and now they have started to show light corrosion (where the pads is not working).
Project:
08 Feb 2020 06:47 - 08 Feb 2020 07:06
#818804
Here's a picture of new KZ650-C1 discs. Notice where they are painted and where they are not painted. Cleaning the unpainted portion should take less than 1 minute per year, so why paint that portion? Ed
[hr]
Last edit: 08 Feb 2020 07:06 by 650ed.
  • z1kzonly
  • z1kzonly's Avatar
08 Feb 2020 07:34
#818810
Discs should not get that hot under normal riding conditions.
Unless your road racing on a course or stopping after a 150 mph 1/4 mile pass at the dragstrip.
I just sold one I painted with automotive clear coat (2K).
You should separate the 2 parts, glass bead the aluminum carrier.
clean the disc. Keep it waxed, (not on pad surface) and it should not rust.
This is what I just did:
  • martin_csr
08 Feb 2020 07:57 - 08 Feb 2020 08:06
#818811
No eBay APP ID and/or Cert ID defined in Kunena configurationI'm assuming he has the typical 80s brake disks found on most models w dual disk Fr brake.
  • Nessism
  • Nessism's Avatar
08 Feb 2020 08:02
#818812
Phosphoric acid is fine fine for derust and clean. It creates an ideal surface to paint over. And that Brake Gray paint should be fine.
  • gordone
08 Feb 2020 10:48
#818819
Nessism wrote: Phosphoric acid is fine fine for derust and clean. It creates an ideal surface to paint over. And that Brake Gray paint should be fine.
Agree :)
My understanding is that the acid make a good surface (no need for primer).
Project:
  • gordone
08 Feb 2020 10:49 - 08 Feb 2020 10:50
#818820
My orginal plan was to paint the area where the bolts is located, please see picture below.
But maybe I shall mask and paint everything that the brake is not touching.... maybe that looks niceer ?
hem...
I assume the brake pads will just wrap of paint if it has come some pain on the "zone" where the pads is working ?
Mask as good I can...
Project:
Last edit: 08 Feb 2020 10:50 by gordone.
  • Nessism
  • Nessism's Avatar
08 Feb 2020 11:02
#818822
Agree :)
Still need primer. The phosphate retards rust in steel but it's not primer.
