Hole in dash on Z1
  • Rick H.
  • Rick H.'s Avatar
Re: Hole in dash on Z1
20 Jan 2020 18:04
#817520
Just to muddy up the water a bit, when I bought my 1975 Z1B new it came with a weird looking keyfob. It was oval shaped 2 piece plastic item roughly 2" long and my ignition key was attached to it with a chain. I didn't have a clue what the thing was really for, so I asked my salesman. He walked me over to the bike and stuck the plastic oval shaped keyfob into the oval hole on the gauge panel and said there, now you know what it's for. What you were supposed to put into the plastic container I will never know, but I folded up my registration card and put it in the oval fob. As a bonus the salesman said the fob will float in water and I thought oh that's just great! The fob had the name of the dealership and telephone number on it so it may have been something they invented, but I never saw a plastic or rubber plug come stock in the oval hole.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • hardrockminer
  • hardrockminer's Avatar
20 Jan 2020 19:15
#817521
The rubber bung for the Keyholder hole was not used in North America. I was found on bikes in some European countries and also in Japan on the Z2.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
21 Jan 2020 02:50
#817529
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • TexasKZ
  • TexasKZ's Avatar
21 Jan 2020 04:04
#817531
Kidkawi solved the mystery once before in 2013.
kzrider.com/forum/6-paint-a-bodywork/576...shboard-why?start=20
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
22 Jan 2020 04:39
#817598
Guy in Germany made a short run of them about 8 yrs. ago. Maybe a guy in Australia at about the same time also (that you, Kidkawie?)
Info we have is they weren't present in most countries. They seem to be pretty much localized to Germany, but unsure if elsewhere.
The part # mentioned earlier and in the fleaBay posting should be correct. The pic below is from a Euro parts manual. We don't have the mating page that lists part #'s. The part identified as item #51 is not present in any of our N. American parts manuals, or in any service bulletin.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
  • martin_csr
  • martin_csr's Avatar
22 Jan 2020 06:14
#817602
By Robb2018: I like your Lowes plug for a buck and a half. No need to cut a slot.
Assuming a plastic plug from wherever will fit the hole. I have no idea what the diameter is.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
26 Jan 2020 05:26 - 26 Jan 2020 05:27
#817926
Yes, I got mine from Achim years ago. IIRC, there is an aftermarket dash without the hole?
1975 Z1 900
2004 KX125
Last edit: 26 Jan 2020 05:27 by Kidkawie.
  • Mikaw
  • Mikaw's Avatar
29 Jan 2020 20:33
#818212
  • SWest
  • SWest's Avatar
  • 10 22 2014
