Hole in dash on Z1
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
Hole in dash on Z1
19 Jan 2020 07:42
#817429
I'm surprised a search didn't turn up something on this subject. Does anyone know the purpose of the hole between the tach and speedo on the Z1 and is there suppose to be a rubber grommet in the hole?
KZ900; Z1
  • 73z1
  • 73z1's Avatar
Re: Hole in dash on Z1
19 Jan 2020 07:58
#817432
Hole above switch is "key holder", no grommet so you can "hold your keys"
The following user(s) said Thank You: Robb2018
  • z1kzonly
  • z1kzonly's Avatar
19 Jan 2020 07:59 - 19 Jan 2020 08:00
#817433
"You are Correct Sir"
There was even a decal that said that when new, the real ones.
Last edit: 19 Jan 2020 08:00 by z1kzonly.
  • Robb2018
  • 76 KZ900 73 Z1 A
19 Jan 2020 08:12
#817435
Strange... Now I'm wondering exactly how that's supposed to work. Is it so the keys don't go bouncing around and scratching up the panel? So it's like... when the Z1 key is in the ignition, one of the other keys dangling from your keychain is supposed to go in the hole? One of those things that's not important but just provokes thought. Really doesn't make a lot of sense.
KZ900; Z1
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jan 2020 08:19
#817436
There's a rubber grommet that goes in the hole available but I won't pay what they're asking for it. STUPID idea anyway. :lol:
  • Robb2018
  • 76 KZ900 73 Z1 A
19 Jan 2020 08:37
#817438
I can only imagine what they'd charge for that. You might be better having one custom made out of solid gold.
KZ900; Z1
  • Warren3200gt
  • Warren3200gt's Avatar
19 Jan 2020 09:29 - 19 Jan 2020 10:17
#817439
There was a rubber bung which fitted that had a slot in it to slot a key in. Always missing now leaving a unsightly hole so I made a plug to cover it.
Last edit: 19 Jan 2020 10:17 by Warren3200gt.
  • martin_csr
  • martin_csr's Avatar
19 Jan 2020 11:08
#817453
Possible solution. or something similar.
Lowes Hillman plastic hole plug
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Jan 2020 12:06
#817455
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
The following user(s) said Thank You: z1kzonly, Nessism, BCScott, Robb2018, 2manybikes
  • Robb2018
  • 76 KZ900 73 Z1 A
19 Jan 2020 12:35
#817456
Great idea. How did you cut that perfect slot?
KZ900; Z1
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Jan 2020 13:02
#817459
Its not my idea, thats a direct copy from an original of what is supposed to be in there. There is a part number, but I dont know it offhand. From what I gather it was a desler prep item that was overlooked.
Ask around on Z1 owners forums to find one.
1975 Z1 900
2004 KX125
  • Robb2018
  • 76 KZ900 73 Z1 A
19 Jan 2020 13:31
#817460
I like your Lowes plug for a buck and a half. No need to cut a slot
KZ900; Z1
