Front Suspension
- gordone
Front Suspension
02 Oct 2019 22:25 - 02 Oct 2019 22:26
Hi,
When I rebuilded my bike I replaced some parts in the fork suspension to get it good as new, so my current setup is from the top, below.
My question is pre compression of the spring, right now I have nothing installed, its only the cap fork top who is pushing the spring down...
I`m a heavy person around 140 pounds, so I was thinking maybe the driving handling is not optimal? and can be better?
Cap Fork Top
440291005
Fork Spring Kit
www.z1enterprises.com/fork-spring-kit-11-1106.html
Pipe Fork Inner
39093-1067
Cylinder Fork Gearhead
44022-1071
Oil
248 cc
Cap Fork Top
440291005
Fork Spring Kit
Pipe Fork Inner
39093-1067
44022-1071
Oil
248 cc
Project:
Project:
Last edit: 02 Oct 2019 22:26 by gordone.
- Warren3200gt
Re: Front Suspension
03 Oct 2019 03:37
what fork oil are you using Gordone? Changing the fork up to a thicker one makes a big difference and is easier and cheaper than messing with springs or spacers. Thicker oil gives slower compression, ie stiffer and slower rebound.
- EA6BMECH
03 Oct 2019 04:10
I don't know what the fill level is on that bike...but, what you can do is cheat it some with putting maybe about and inch/25mm more of oil. That will increase the air pressure inside the forks when it comes to compression. My ST1300 is a little weak on the fork springs, but the oil level is only about 65mm. Many bikes are maybe around 100-155mm. Anybody correct me if I'm wrong.
03 Oct 2019 05:11
While sitting on the bike and not moving the ideal situation is for 25% of the fork (& shock) travel to be compressed. That leaves the other 75% of movement to absorb bumps on the road. If you have more than 25% add a spacer into the fork to lift the front end. If you have less, then your fork springs are too stiff.
- gordone
03 Oct 2019 05:27Nessism wrote: While sitting on the bike and not moving the ideal situation is for 25% of the fork (& shock) travel to be compressed. That leaves the other 75% of movement to absorb bumps on the road. If you have more than 25% add a spacer into the fork to lift the front end. If you have less, then your fork springs are too stiff.
Thank you !
Will test these!
When it comes to the filling level shall I just follow recommend filling level from the service manual?
Project:
Project:
03 Oct 2019 06:31
As I recall, the factory suspension was designed for a 150 pound rider, which in the U.S. is very light for male riders. Nessism is correct about setting sag befor changing anything else. Ohlins used to have a really good article on the subject on their website. I know there are others on the web.
03 Oct 2019 06:40
03 Oct 2019 14:29
140 lbs is a very light rider. Did you mean 140 kg?
A "heavy" 140 Pounds of an rider is a light weight 70 kg Person. gordone , what´s your real weight???
Last edit: 03 Oct 2019 14:48 by Scirocco.
- gordone
My real weight is 110-115kg
Project:
Project:
04 Oct 2019 04:54 - 04 Oct 2019 04:57
By gordone: My real weight is 110-115kg
So you're about 240 pounds. not 140. probably had a typo in the topic post.
I think the fork spring kits typically require a spacer. some guys make a spacer from pvc pipe.
Last edit: 04 Oct 2019 04:57 by martin_csr.
- gordone
04 Oct 2019 06:06martin_csr wrote: By gordone: My real weight is 110-115kg
Guess I shall make a spacer based on these test fail and trie serval times ?
Project:
Project:
