anybody measure swing-arm bushing using rear axle end-play?
  • SpecialGreen
  • SpecialGreen's Avatar Topic Author
16 Aug 2019 16:45 - 16 Aug 2019 17:26
#809287
When I pull my rear wheel side-to-side, there is enough slop in the swing arm bushing for it to move about 26 thou (1.57mm) side-to-side (axle end-play). I wasn't sure if anybody measures the swing arm bushing this way.
5-second movie:
www.dropbox.com/s/4wobzru3947vv93/25-tho...m-swingarm.mp4?raw=1
EDIT: the bike is a '77 KZ400
Last edit: 16 Aug 2019 17:26 by SpecialGreen.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: anybody measure swing-arm bushing using rear axle end-play?
16 Aug 2019 16:50 - 16 Aug 2019 17:12
#809289
You Need new swing arm brass bearings!!! (upgrade to needle bearings). What bike do you talk about?
Last edit: 16 Aug 2019 17:12 by Scirocco.
  • SpecialGreen
16 Aug 2019 17:58 - 16 Aug 2019 18:12
#809294
No eBay APP ID and/or Cert ID defined in Kunena configurationIt looks like '77 Kz400D4 has:
- sleeve 33034-028
- bushing 33033-009
I can pull them (hopefully Sunday) and measure the outer diameter of the sleeve with a micrometer. At $40 each, i won't replace unless they need it.
But I don't have a "cylinder gauge" to measure the inside of the brass bushing (is tthere a workaround way to measure?). I think I can probably assume that they need a refresh, though this bike has only 16k miles (but doubtful anybody ever lubed it).
I see a guy in Germany making plain brass ones (a pair for $24 shipped... if I can wait 3 weeks)
... he claims that they fit a whole bunch of Kawi's, so if there is a needle bearing replacement for any of these bikes, then it may fit:
KE 125 KE125A3-5 76-78
KS 125 KS125A 74-75
Z 200 KZ200A1-2 78-79
250 F11 F11 73-75
KE 250 KE250B1-3 77-79
KH 250 (3 Zyl.) S1 74-76
KL 250 KL250A1 78
Z 250 KZ250D1-2 80-81
KH 350 (3 Zyl.) S2 73-75
KH 400 (3 Zyl.) S3 76-78
Z 400 (2 Zyl.) KZ400A1-2 77-78
Z 400 (2 Zyl.) KZ400D 75-77
KH 500 (3 Zyl.) H1 72-76
Z 650 B KZ650B1 77
KH 750 (3 Zyl.) H2 74-75
Z 750 B (2 Zyl.) KZ750B1-4 76-79
Z 900 Z1 73-76
Last edit: 16 Aug 2019 18:12 by SpecialGreen.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2019 18:39
#809304
There should be no slop in the rear end.
