Kz200 seat cover options
  • catfishsalad
  • catfishsalad's Avatar Topic Author
06 Jun 2019 07:49
#805237
Looking at replacement seat covers for my kz200 and it seems like I can save a couple weeks of shipping time if I can used a kz400 cover instead. Anyone have dimensions on a kz400 seat?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz200 seat cover options
06 Jun 2019 08:13
#805238
PICS OF WHAT YOU HAVE?
  • martin_csr
  • martin_csr's Avatar
06 Jun 2019 11:37
#805249
You probably ought to get the correct seat cover. An ill-fitting cover is probably going to be more trouble to install & probably won't look very good afterwards. Whatever seat cover you get, it will probably have instructions. I installed a Travelcade saddlemen seat cover which fit perfectly. The instructions suggested using 3m Super 77 spray adhesive & only spray the top of the foam, not the sides. I did some common sense prep beforehand, including sanding the remaining dried up stuff from the old foam.
  • catfishsalad
06 Jun 2019 12:42 - 06 Jun 2019 12:46
#805256
this is what I’ve got. May end up cutting out a bit of foam and reshaping a new piece where it’s damaged. Down the road I may hoop the frame and fit a brat seat, so I’m not going to go crazy making this perfect. I’ve used super 77 on other seats as recommended and got good results. Thanks!
Last edit: 06 Jun 2019 12:46 by catfishsalad.
