break actuator
  • bergerbut
  • bergerbut's Avatar Topic Author
break actuator
16 Apr 2019 11:48 - 16 Apr 2019 11:57
#802237
what lubricants are best when installing the
break acuuator?
I was planning on using a wheel bearing grease .
Last edit: 16 Apr 2019 11:57 by bergerbut.
  • jayrodoh
  • jayrodoh's Avatar
Re: break actuator
16 Apr 2019 12:49
#802239
Wheel bearing grease is fine for this application.
1982 KZ750-M1 CSR
The following user(s) said Thank You: bergerbut
  • martin_csr
  • martin_csr's Avatar
Re: break actuator
16 Apr 2019 13:26 - 16 Apr 2019 13:32
#802242
I use Permatex Ultra disk brake caliper lube in the little packets & additionally apply a little on the brake shoe pivots.
And also use it on the levers, brake pedal shaft & cable ends as it stays put, is waterproof and resists dust & grit.
One of those little packets lasts a long time & they're sold as a pair. It now also comes in a small tube.
Are you installing new brake shoes?
Last edit: 16 Apr 2019 13:32 by martin_csr.
  • jayrodoh
  • jayrodoh's Avatar
Re: break actuator
16 Apr 2019 15:03
#802245
Martins advice is better, I misread and thought you were taking about the brake pedal pivot.
1982 KZ750-M1 CSR
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: break actuator
16 Apr 2019 15:38
#802248
I use wheel bearing grease on the working parts in drum BRAKES. I'd rather have waterproof wheel bearing grease but like all the good things it is being phased out by the do gooders. :angry:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: break actuator
16 Apr 2019 15:53
#802250
I would use copper grease on brake parts but anybody has a special magical grease for the field of application.
  • martin_csr
Re: break actuator
17 Apr 2019 06:18
#802273
By SWest: I use wheel bearing grease on the working parts in drum BRAKES. I'd rather have waterproof wheel bearing grease but like all the good things it is being phased out....
You must use a lot of grease. I've had a tub of Bel-Ray marine waterproof grease for years & it's more than half full >> I used it on the fork & wheel bearings. Maybe a boat shop has something?
For the drum brake I prefer disk brake grease as it's high temp, resists moisture & doesn't wash out plus it's intended for brakes. also, I think it's kind of electro-neutral, so it doesn't attract dirt & grit.
  • bergerbut
Re: break actuator
17 Apr 2019 06:50
#802276
yep;; this bike sat for 35yrs;;; old ones fell right off
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: break actuator
17 Apr 2019 07:28
#802279
Bendix white lithium brake grease.
Low/no volatiles or fluids, so it doesn't migrate (creep) across surfaces.
We've had the can for years. A little goes a long way.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
