inverted front end
  • dustygpz
  • dustygpz's Avatar Topic Author
inverted front end
30 Dec 2018 09:04
#795919
are there any other options out there to convert my 84 gpz 1100 to inverted front end other than cognito moto ?
  • davido
  • davido's Avatar
Re: inverted front end
30 Dec 2018 11:46
#795924
I used the front end from a ZX9R on my CSR build. Supposedly the longest of the Jap front ends. Still came out too low though. I ended up having fork extenders made up on the lathe. Plenty of clearance now.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • TexasKZ
  • TexasKZ's Avatar
30 Dec 2018 12:59
#795926
You can use basically any male-slider front suspension by swapping the KZ stem into the new lower clamp. However, as davido mentioned, most of the newer forks are much shorter, and you will
be going to a 17 inch front wheel unless you can make the spacers and brake mods to use the stock KZ wheel.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
30 Dec 2018 16:51
#795940
You could check the add at the bottom of the page, PDM, I know they've done a few. :whistle: :whistle:
Les Holt
  • TexasKZ
  • TexasKZ's Avatar
31 Dec 2018 06:16
#795958
Indeed. PDM can fix you up with some sexy custom parts.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
31 Dec 2018 06:55
#795963
les holt wrote: You could check the add at the bottom of the page, PDM, I know they've done a few. :whistle: :whistle:
Les Holt
Yes They sure can , And Much More !!!!!!!!!!
Thanks Les
  • dustygpz
02 Jan 2019 13:14
#796072
fork extenders sounds interesting , would you possibly have photos of what you made ?
  • davido
  • davido's Avatar
02 Jan 2019 13:22 - 02 Jan 2019 13:24
#796073
My build thread has all the details of the forken extensions,somewhere towards the bottom of this page;
www.kzrider.com/forum/11-projects/594313...ject-build?start=520
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 02 Jan 2019 13:24 by davido.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
02 Jan 2019 13:41
#796074
I use the same ZX9R fork, exept for the 6 Piston front brake caliper mount spacing, on my Project bike.
Never had any problems with the ground to header (Marving) when cornering hard.
  • dustygpz
02 Jan 2019 14:38
#796078
very nice ,have to call an old friend ,I know he can make me some
  • dustygpz
02 Jan 2019 14:43
#796079
looks good , ill be using 06 r1 front end and rear wheel that im building my own swingarm to fit it in
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
02 Jan 2019 15:55
#796083
YZF R1 RN12 (04-06) = 730 mm length
ZX-9R (94-97) = 775 mm length
