750B upgrade to ZG1000 calipers, what rotors?
  • jimbrickland
  • jimbrickland's Avatar Topic Author
15 Dec 2018 08:57
#795173
Hello KZRiders,
I recently was able to pick up a set of 1986 zg1000 calipers for a song and after mocking up the fit with some KZ650 rotors I had lying around I realize I need to go rotor shopping. The rotor diameter is too small. I have seen other threads recommending KZ1000 rotors with GPZ750 calipers, which look similar to the ZG1000 grabbers that I already have. Just looking for some confirmation, are the KZ1000 rotors going to be the ticket? Thanks as always.
1976 KZ750B my one and only
1983 KZ440 LTD my one and only's one and only
  • jimbrickland
Re: 750B upgrade to ZG1000 calipers, what rotors?
15 Dec 2018 09:30
#795179
So , a little bit of sizing research I have been able to do may give you guys an easier time answering my question.
KZ750 Stock Rotor Diameter - 245mm
KZ650 Stock Rotor Diameter - 245mm
ZG1000 Stock Rotor Diameter - 272mm
KZ1000 Stock Rotor Diameter - 296mm
Obviously, this needs to be right on the money when it comes to sizing. I would say the KZ650 rotors that are mocked up are about halfway up the pad surface. I need the 4 bolt pattern I would be able to get from the KZ1000 rotors but I want to confirm that the diameter wouldn't be too large. Thanks!
15 Dec 2018 09:48 - 15 Dec 2018 09:53
#795182
Different model KZ650 bikes had rotors with different diameter and thicknesses. The KZ650B and E models had front rotors with a swept area of 250mm and a thickness of 6.9-7.1mm. The KZ650C, D, and F models had front rotors with a swept area of 231mm and a thickness of 4.9-5.1mm. Ed
Last edit: 15 Dec 2018 09:53 by 650ed.
  • jimbrickland
15 Dec 2018 10:41
#795184
Thanks for the insight Ed. I believe these are the thinner rotors but I will have to put a tape on them when I can get back to the workshop. I have made peace with not being able to use those rotors though. Any thoughts on the sizing I should be looking for to use on the 750B with the ZG1000 calipers?
  • DoctoRot
  • DoctoRot's Avatar
16 Dec 2018 13:57
#795245
i have found this website helpful when looking for disks to swap
www.metalgear.com.au/search_by_disc_measurements.php
