900/1000 wheel swap
  • TerryK
  • TerryK's Avatar Topic Author
900/1000 wheel swap
21 Aug 2018 16:22
#789501
Anyone know if a KZ900 front wheel with work on my KZ1000 front end? The hubs are completely different and the axle looks different as well. Id just try it but I don't have the forks fixed yet (bent). Had a crash with a car and Im just trying to get it back together to finish out the riding season. Any help is appreciated!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • z1kzonly
  • z1kzonly's Avatar
Re: 900/1000 wheel swap
21 Aug 2018 16:37
#789504
That KZ1000 has to be an 81-82, A CSR or LTD. Has a J-model engine. Different!
  • TerryK
21 Aug 2018 16:51
#789506
Mine is a 77' 1000A, the wheel I think is a 75-76 900.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Aug 2018 16:59
#789507
The 76 900 has a four bolt rotor.
  • TerryK
21 Aug 2018 17:12
#789509
As does my 1000, but the 900 wheel has a 6 bolt rotor. That a 73-74 wheel?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • SWest
  • SWest's Avatar
  • 10 22 2014
