1977 KZ1000 A1 Speedo cable
  • Wilcocar
  • Wilcocar's Avatar Topic Author
05 Aug 2018 10:56
#788243
I have searched high and low for a new speedo cable for my bike and bought one from Z1 enterprises with it saying it would fit my KZ right when it came in on the bag it said KZ 650/750. Right connections just 2 inches short! Does anyone know where I can buy the right one! Thanks in advance.
Carson
1977 KZ1000 A1
  • hardrockminer
  • hardrockminer's Avatar
Re: 1977 KZ1000 A1 Speedo cable
05 Aug 2018 13:33
#788256
Have you tried Kawasaki?  I've ordered OEM cables through Partzilla for my Z1's.
  • z1kzonly
  • z1kzonly's Avatar
05 Aug 2018 13:59
#788262
What length do you need? Pull your original tight. measure the aluminum threaded ends. End to end. the aluminum threaded pieces.
I have a pile of OEM cables sitting.
I might have one.
I am in New York State.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
05 Aug 2018 13:59
#788263
Contact Z1 Enterprises & they should make it right.  Don't let 'em slide on their mistake.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Wilcocar
05 Aug 2018 14:16 - 05 Aug 2018 14:21
#788267
Yes, I could get one from kawasaki but they were 3 times the price and over a week out. I have found some OEM ones online now. I will try to get one out of Z1 if they won’t then I will try D2moto they say they have one. Thanks!
1977 KZ1000 A1
Last edit: 05 Aug 2018 14:21 by Wilcocar.
  • TexasKZ
  • TexasKZ's Avatar
05 Aug 2018 18:22
#788288
Partzilla has it for $22, but I am sure Z1E will make it right.
  • RonKZ650
  • RonKZ650's Avatar
06 Aug 2018 18:08
#788359
If you are buying cables for the motorcycle pictured in your avatar, don't order a cable for an A1 as it will always be too short. The A1 should have the caliper mounted in front of the fork leg and they used a short cable that shot more or less straight down from the speedo to the wheel. KZ650B1 for 1977 was the same setup. Next year in 1978 when they moved the caliper behind the fork leg, they then routed the cable behind the caliper, so it takes a cable a bit longer. Be sure and get the cable for the A2 if you want it long enough (with any luck), as your calipers behind the legs need the longer cable.
The following user(s) said Thank You: Scirocco
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
10 Aug 2018 10:16 - 10 Aug 2018 10:18
#788617
Carson, the cable we sold you was correct for the KZ1000-A1. Your bike is not 'all original' - it isn't even close to being all original. It has the forks reversed with the calipers behind the forks - and as a consequence, needs a 2" longer cable. When you look at the calipers on your bike, you will see the bleed nipples point back to the engine...
Your bike is a mix of KZ900 bodywork with some LTD and aftermarket parts on a KZ1000A. The KZ1000-A1 came with a single front disk - with the caliper ahead of the forks. It also came with a nice 4-2 exhaust - and not a turnout exhaust - nor did it have an LTD seat when it left the factory,.
If you don't trust my knowledge of your bike, post a picture of it for others to help you understand what you have...
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 10 Aug 2018 10:18 by Jeff.Saunders.
  • davido
  • davido's Avatar
10 Aug 2018 10:24
#788619
So are you going to sort him out with the right cable for his bike?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Jeff.Saunders
  • Vendor
  • Vendor
10 Aug 2018 10:33 - 10 Aug 2018 10:39
#788620
We would like to - and we have tried to help Carson... I think the ball is in his court at the moment.
The cable he needs would normally be used on the LTD model - which did have the calipers behind the forks. Our part number is TU06-3123
TU06-3123
Z1 Ent on Facebook,
Last edit: 10 Aug 2018 10:39 by Jeff.Saunders.
  • z1kzonly
  • z1kzonly's Avatar
10 Aug 2018 12:59
#788625
z1kzonly wrote: What length do you need? Pull your original tight. measure the aluminum threaded ends. End to end. the aluminum threaded pieces.
I might have one.
You should have measured the one the broke on your bike, as I said I have a pile of them. I was going to give it to you for free, and have you just pay the shipping.
  • davido
  • davido's Avatar
10 Aug 2018 15:13
#788630
Jeff.Saunders wrote: We would like to - and we have tried to help Carson... I think the ball is in his court at the moment.
TU06-3123
Thats fair enough.You cant ask more than that.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
