break actuator
- bergerbut
break actuator
27 Jul 2018 16:17
looks like I ordered a long one ;;; originally it had a shorty;;;; will the long one work ;;; '74 Z1;;;
Re: break actuator
27 Jul 2018 16:21
Doubt it but you could try. Might be to "grabby".
- slmjim+Z1BEBE
Re: break actuator
27 Jul 2018 16:27
Don't think there will be enough brake pedal travel to swing the long lever through a useful arc and still release the shoes at rest.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Re: break actuator
27 Jul 2018 16:59 - 27 Jul 2018 17:04
The short one should work fine on a stock bike.
The long one need a lot of brake pedal travel for the same brake performance!!!
The performance and travel is dependent of the actuator angle on the brake pad cam rod!!!
Last edit: 27 Jul 2018 17:04 by Scirocco.
Re: break actuator
27 Jul 2018 17:12
It can be moved forward and adjusted tight. My concern would be too much leverage causing unwanted lock up.
The following user(s) said Thank You: bergerbut
- bergerbut
Re: break actuator
28 Jul 2018 11:50 - 29 Jul 2018 09:19
Rear Brake. I would install the correct brake cam lever & adjust the Rr brake according to the manual.
Brake Shoes. If you don't know the age of the brake shoes or, replace them. The adhesive that binds the linings to the shoes can fail over time, so a lining can break loose & get jammed between the shoe & drum, locking the rear wheel. It happened to me, so it does happen. I was lucky that it happened in the driveway when rolling the bike off the center stand. It would be a real drag at speed & far from home.
BRAKE.
BRAKE.
Last edit: 29 Jul 2018 09:19 by martin_csr.
- bergerbut
Re: break actuator
28 Jul 2018 13:46
;;;lol;;; u are so right ;;; 35 year old breaks just fell off ;;;;;;; actually this project is a complete nut & bolt restriction ;;;;
Re: break actuator
28 Jul 2018 17:13
Found coincidentally the same fell off break pads like yours on a 81 HONDA CM400. Have to pull the rear wheel, was out of the middle in the swing arm.
(PO switched the distance collars). Safe my friends life/health.
- bergerbut
Re: break actuator
29 Jul 2018 09:39 - 29 Jul 2018 10:35
Rear brake carnage. not mine. I don't know the cause. I believe the pics were posted here on KZR, quite a while ago.
Last edit: 29 Jul 2018 10:35 by martin_csr.
Re: break actuator
29 Jul 2018 14:59
I remember this rear break failure post.
Rear wheel brake pads fell off and block the rear brake drum so hard that all parts break off and spin around the wheel.
No thanks, don´t want think about it any more why people want to save 20 bucks on safety parts.
PS: Have to ask. Where can i find the emoticons? The new board software made me crazy, aaarrgghh
