'74 z1 sprocket spacer
  • bergerbut
  • bergerbut's Avatar Topic Author
17 Jun 2018 15:34
#785332
Im refurbishing a '74 z1 , it had a 37 tooth aftermarket sprocket no spacer , how do i know if i need the spacer with my new sprocket ?
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: '74 z1 sprocket spacer
17 Jun 2018 19:53
#785359
If you're talking about the thin spacer that goes between the sprocket and sprocket carrier, the spacer is needed if you're running an O-ring chain.. A matching spacer is needed for the countershaft sprocket too, to maintain alignment. Some aftermarket countershaft sprockets had the spacer machined into one side, so they could be used with either type of chain.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: bergerbut
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Jun 2018 20:58
#785361
Haven't used one for years.
  • hardrockminer
  • hardrockminer's Avatar
18 Jun 2018 08:09
#785381
SWest wrote: Haven't used one for years.
If you're running 630 o-ring chain with an early sprocket (no shoulder) your chain will rub on the outside of the tranny cover. The purpose of a shoulder on the sprocket is to provide clearance for the extra width of an o-ring chain.
  • slmjim+Z1BEBE
18 Jun 2018 10:08
#785382
Yup. We've seen many tranny covers scored because of that. Lots of metal shavings in the grunge surrounding the countershaft sprocket.
Seems like Mama Kaw made a shim for the countershaft for that too? We'd have to dig through the Service Bulletins...
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • hardrockminer
18 Jun 2018 13:40
#785391
Yep! I have one with the score marks. The chain actually rubbed the head off one of the tranny cover screws too.
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Jun 2018 14:46
#785396
My sprockets come with the shoulder. Even then it's a tight fit. Been thinking about using washers to space the rear sprocket instead of buying a NOS from a eBay SHARK.
As I said I haven't been running one for years. No problems.
  • hardrockminer
19 Jun 2018 12:08
#785433
It's not necessary to use a stock one on the rear but whatever is used...it needs to be at least the same diameter as the sprocket bolts or there is a risk that the bolts will "bend" the sprocket when torqued up.
Using nothing is kind of like having high blood pressure and not taking medication. You won't notice anything different but there will be wear on the sprocket and chain due to misalignment.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2018 13:41
#785437
No misalignment. The most important part is the countershaft sprocket.
  • hardrockminer
19 Jun 2018 15:10 - 19 Jun 2018 15:17
#785451
There would be misalignment if the front sprocket had a shoulder (as the photos show) and the rear sprocket didn't have the spacer specified in the parts manual. When KHI switched to O-ring chain they added both, along with a re-designed chain guard to prevent rubbing. There were other changes made as well. The chain adjusters were narrowed, the muffler mounting bolts were shortened, and I believe the engine mount bracket was modified. All in all it's a great education on all the related things that can happen when something as simple as a chain is modified.
Last edit: 19 Jun 2018 15:17 by hardrockminer.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2018 19:58 - 19 Jun 2018 19:59
#785478
At least 10.000 miles on this one. First a NOS O ring chain, when it developed tight spots a new Gold high performance O ring chain (made in china) then a standard 630 chain until I could afford a whole new setup. See any misalignment marks or undue wear?
:) The O ring chains are wider inside and out. Plenty of room for it to glide happily doing it's job for 1000's of miles.
BTW, my chain guard was the same as Larry's Z1a and Jim's 73 Z1.
I've had my Z1b 43 years. It's changed after the wreck so I'd like to see some pics of the changes you've described. :huh:
Last edit: 19 Jun 2018 19:59 by SWest.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
19 Jun 2018 20:10
#785479
The manufacturing tolerances 45 years ago will smoke off the 1,5 mm spacer!!!
