Wheel lacing question
  • ayeckley
  • ayeckley's Avatar
Re: Wheel lacing question
30 Dec 2017 05:15 - 30 Dec 2017 05:19
#776747
I went through this process last summer on the front wheel of the KZ1000. Make sure to order the spoke wrench they sell also since the Buchanan nipples have larger diameter wrenching flats than the OEM spokes. The torque spec is also surprisingly high compared to the FSM value, so a good wrench is mandatory. Adds about $20 to the total cost, at least when ordered directly from Buchanans.
Oh, and at least with the front wheel no "forming" (I do like that term over "bending") was required. The angles and lengths were exactly the same as the OEM spokes being replaced.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
Last edit: 30 Dec 2017 05:19 by ayeckley. Reason: More info & clarification
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
30 Dec 2017 07:32
#776750
Spokes are no different than any other threaded fastener. There's a correct torque spec.
Part of the spec is to ensure the threads are not stretched excessively or stripped altogether.
When it comes to spokes in hub flanges, flanges can be damaged/cracked/pulled apart & separated from the hub body completely due to the combined tension of many over-torqued spokes pulling on the flange in unison. That combined tension force on the flanges is part of the reason the spoke torque spec is what it is.
Spokes too loose will result in a wheel that won't remain true. Spokes too tight will often break at random intervals, and may result in damage to the hub flanges.
A couple of good torque wrenches are in any competent DIYer's tool chest. Spokes are no different, and are arguably more critical to safety than, say, correct torque on head nuts.
Tusk and Fasst Company both offer adjustable spoke torque wrench sets with interchangeable ends. Highly recommend for anyone wishing to learn wheel building. Both can be found on a variety of websites. Others are available pre-set to one torque spec, if that one spec is all it is to used for. Cheaper, but not as versatile.
When we started our first foray into wheel building, we bought the Fasst Company adjustable spoke torque wrench set, as well as a regular fixed-size spoke wrench for general use.
kz650guy,
If you're using stainless spokes along with with stainless nipples, Buchanan recommends stainless thread lube to keep the threads from seizing during tensioning.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 Dec 2017 20:52
#776770
The equal torque or tension, (not the right torque!), of a spoke can be sound checked like a guitar string with light tabs on the spokes.
Just for your first check. Wheel spoke truing professionals have a better hand, eye, sound and torque feeling like us.
  • kz650guy
  • kz650guy's Avatar Topic Author
07 Jan 2018 21:59
#777038
New spokes went in without problems much better quality than emgo it did come with some assembly lube easy install much better fit and the spokes are thicker than original and the emgo spokes
  • DoctoRot
  • DoctoRot's Avatar
08 Jan 2018 10:33
#777068
the Emgo spokes are OK for the money. I have laced two sets of wheels with them and had the same problem with the spoke bend being incorrect on one. I called up a professional wheel builder to ask advice and he said he bends spokes by hand all the time. So i bent them to fit and haven't looked back since. Buchanan's makes a far superior product but spokes for two wheels at $220 is pretty steep.
  • kz650guy
16 Jan 2018 17:28
#777338
Started on the front spokes rim has several dents in it and will need replaced spokes are usable but do not look anywhere near as good as the rear spokes I really don't want to buy 130 dollar spokes and a 65 dollar rim but I don't think I would be happy with these old spokes on a new rim I'll post some pic when I get home
  • DoctoRot
  • DoctoRot's Avatar
16 Jan 2018 23:04
#777346
you could get them replated. I found a place that will zinc plate up to 35 pounds for something like $65. if you're doing a resto, you could get other hardware plated.
  • slmjim+Z1BEBE
17 Jan 2018 08:00
#777350
Try aluminum paint. It won't look as good as new spokes, but will look surprisingly good at a glance.
Good Shootin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • kz650guy
17 Jan 2018 17:57
#777372
Not a bad idea I think I'm just going to replace the rim for now and put the spokes in some evapo rust just to clean them up a bit I will replace them the next time I change front tire probable be a few years already spent to much in parts but that's how it goes
  • kz650guy
23 Jan 2018 17:50 - 23 Jan 2018 17:52
#777662
Finally got it all done I've been converting my 76 ltd 900 to a kz clone the wheels are from a 77 kz750 twin all bolt on
Last edit: 23 Jan 2018 17:52 by kz650guy.
  • DoctoRot
  • DoctoRot's Avatar
25 Jan 2018 15:25
#777770
looks great
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
25 Jan 2018 16:04
#777775
Nice job on the wheel swap.
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
