Will a 1977 KZ650 front rotor fit a 1976 Kz900?
  • 650Dude
  • 650Dude's Avatar Topic Author
  • Banned
  • Banned
23 Dec 2017 06:27 - 23 Dec 2017 06:32
#776537
Sorry. This site seems to be slow and buggy today. I meant to post this in "bike related" not "engine." Anyhow,
I just got a Kz900 for xmas (picking it up today) and I like all of my rotors drilled so I can put a disc lock on them. I have a spare KZ650 rotor and am wondering if that will fit the KZ900 so I can go ahead and get it drilled.
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Last edit: 23 Dec 2017 06:32 by 650Dude.
  • z19OO
  • z19OO's Avatar
Re: Will a 1977 KZ650 front rotor fit a 1976 Kz900?
23 Dec 2017 07:37
#776541
I know the disc will bolt on but not sure if the disc is larger on the 900.
1975 z1 900
1979 kz650b
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Dec 2017 07:48
#776543
If 11 5/8" it will work.
  • 650Dude
  • Banned
  • Banned
23 Dec 2017 07:56
#776545
z19OO wrote: I know the disc will bolt on but not sure if the disc is larger on the 900.
Im picking up the bike tomorrow. The seller says it needs a battery. Since I dont even had a manual yet, whats a good battery for a 76 KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Dec 2017 08:09 - 23 Dec 2017 08:10
#776548
If you need it now you can get one at AZ, OR, Wally, etc. 14ah Or you can order on line for a better one with a 1 year warranty..
Lots to chose from.
Last edit: 23 Dec 2017 08:10 by SWest.
  • howzit
  • howzit's Avatar
23 Dec 2017 16:53
#776566
If your bike is: KZ900-A4 (1976), the disc off your 76 KZ650 is the same part. Part number is 41080-005
The following user(s) said Thank You: z19OO
23 Dec 2017 17:16
#776568
STOP!
In order for anyone to accurately answer your question you need to identify which MODEL 1977 KZ650 the donor rotor is from.
The 1977 KZ650-B1 front rotor is not the same size as the 1977 KZ650-C1 front rotors.
The effective disk diameter of the 1977 KZ650-B1 rotor is 245mm, and the rotor thickness is 6.9 - 7.1mm.
The effective disk diameter of the 1977 KZ650-C1 rotor is 231mm, and the rotor thickness is 4.9 - 5.1mm.
The part number howzit gave is correct for the 1977 KZ650-B1 rotor. However, the part number for the 1977 KZ650-C1 front rotors is 41080-1002. So you need to know which model KZ650 the rotor originally came on to determine if it is the same as the KZ900 rotor. Ed
