used brake rotors?
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
used brake rotors?
09 Dec 2017 15:46
#775777
My front brake rotors are under spec (3.6 and 3.8 mm - service limit is 4.0mm). New OEM rotors are $250-300 each. I see some used ones on ebay with ~4.5mm left for $50-100 for a pair. Seems like a much more economical solution. Wondering what kind of experiences people have had with used rotors...
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • NobleHops
  • NobleHops's Avatar
  • Vendor
  • Vendor
  • A happy present from the earth!
Re: used brake rotors?
09 Dec 2017 16:46
#775779
Hey there,
With some paint and professional help you can do fine with used rotors. I've sent a dozen or more rotors to these folks with great results:
www.truedisk.net
One nice thing is that you can repaint the centers of your rotors and not mask the rotor itself, they will grind the paint right off. At $45 per rotor plus ~$40 of shipping (for both ways), it is a good value to end up with rotors that are like new., IMO.
Best,
Nils
Nils Menten * RestoCycle LLC * Tucson, Arizona * USA
Proud sponsor of KZRider: kzrider.com/forum/14-vendor-forum/604812...on-shocks-usa#751083
Vapor blasting with free shipping! www.restocycle.com
Discounted Ikon Shocks! www.ikonshocksusa.com
The following user(s) said Thank You: Zaddict
  • bluej58
  • bluej58's Avatar
09 Dec 2017 19:50
#775783
Get the ebay ones, as long as they are not warped I would run a disk sander around them a few times to clean them up a bit and install them.
If you get them re cut there woun't much left.
78 KZ1000 A2A
