1976 KZ400 D3 Front Brake Caliper Issues
- Jack_Mills
Re: 1976 KZ400 D3 Front Brake Caliper Issues
03 Dec 2017 09:33
Ill take some measurements tomorrow late day and post em here.
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
Thanks goes out to all folks who share their great knowledge teaching others about classic metric motorcycles.
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
03 Dec 2017 11:39 - 03 Dec 2017 11:44
By alinaaseh: I made matters worse ...., and rounded the bolt in the process. No amount of WD40 & plying has made it budge.
If you're using regular wd40, that stuff really isn't a penetrating oil. it's just a light lubricant. They do now make a penetrant, claiming it's better than pb blaster. pbb didn't do as good as Liquid Wrench in a test floating around the internet.
For stuck bolts I use Liquid wrench penetrating spray lubricant. It's readily available & cheap. and it works.
Spray. tap tap tap the part with a hammer & wood block. repeat. let sit overnight. or several nights. spray. repeat.
Kroil is supposed to be best, but it's more expensive & I've never seen it in any auto parts store or hardware store.
Keep in mind that a penetrant may attack the rubber & plastic parts and will contaminate the brake fluid.
So you should remove the rubber/plastic parts before spraying, then disassemble & thoroughly clean everything afterwards.
If your bike has old old old rubber original brake lines, you should replace them.
Last edit: 03 Dec 2017 11:44 by martin_csr.
- DoctoRot
03 Dec 2017 14:15
I really like a 50/50 mix of acetone and ATF for penetrating oil. Works better than anything else i've used and is super cheap to make.
- Jack_Mills
04 Dec 2017 16:31
Hey,
I was unable to take a measurement because the caliper is all back together w fluid in and working, and didnt want to chance anything. I do have the 77 caliper there, I will take some measurements of that hopefully tomorrow. Sorry!
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
- ThatGPzGuy
04 Dec 2017 16:54
No eBay APP ID and/or Cert ID defined in Kunena configurationNo worries.
Mine is back together with the eBay oil seal. So far so good. No leaks and it seems to be working. I also switched over to DOT5 so I am working thru that as well. In any case, it's good to have the KZ400 back.
Here is the link for any other KZ400 people looking for the caliper seal:
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Jack_Mills
04 Dec 2017 17:00
Great news!
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
- ThatGPzGuy
13 Nov 2020 11:19
Update: The seal I purchased from the ebay link above has failed. The bike only has about 20 miles on it but the seal will no longer seal causing the brakes to seep fluid from the caliper.
Back to square one.
Back to square one.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
13 Nov 2020 14:23
That bites.
- ThatGPzGuy
13 Nov 2020 14:34
To his credit the ebay seller has offered to send me another one and to help any way he can.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
